SE 254 or Stock cams
Old May 23, 2013 | 07:29 PM
bob2002's Avatar
bob2002
Default SE 254 or Stock cams
I'm running the Wood 222 cams and because of there 28 degree overlap and the quiet somewhat restrictive mufflers I use the cupping/banging a board with a hammer sound coming out of the throttle body is much more noise then I can live with (2000-4000 RPM at all speeds).
So I'm looking for input if the 254 cams with there 3 degree overlap would eliminate the sound I'm hearing? Or is it back to stock.
PLEASE stick to what I'm asking.
Old May 23, 2013 | 08:05 PM
Juice's Avatar
Juice
why the 254? You picked 222 for torque and a little hp, what about the 204?
Old May 23, 2013 | 09:44 PM
Softy 103's Avatar
Softy 103
I am running the 254e and I don't think I have that sound you are talking about. As far as comparing the 254 to the 204, as mentioned by fmfpj,I am running basically the same set up as him except that I am running 103, with Burly heads stock Throttle body heavy breather and fatcat, tuned with a pro SE race tuner, and am getting 102 hp. and 115 lbs. torque, I am assuming that the 254e is doing everything that the 204 is doing plus some.
Old May 24, 2013 | 10:35 PM
Cliff-AZ's Avatar
Cliff-AZ
I have the TW222's and I'm very happy with them. I am surprised how close they are to stock in terms of engine noise.
If I was you I would just turn up the radio a little louder and save yourself some money and aggravation. You have one of the best cams out there for a stock 103.
Old May 24, 2013 | 10:49 PM
Uncle Chester's Avatar
Uncle Chester
Maybe check your pushrod adjustment, I haven't heard a lot of noise complaints about that cam.
Old May 24, 2013 | 10:50 PM
Uncle Chester
When you say burly heads are you talking about Earl.
Old May 24, 2013 | 11:08 PM
mgmmgm's Avatar
mgmmgm
Odd? I have those cams and do not have the occurrence that the OP reports.
Old May 24, 2013 | 11:09 PM
Teardrop's Avatar
Teardrop
Sounds like you need to get your bike tuned better.
Old May 25, 2013 | 06:01 AM
bob2002's Avatar
bob2002
If I was running an open muffler the noise would be just about gone its because I choose to run quiet mufflers
Old May 25, 2013 | 06:03 AM
bob2002's Avatar
bob2002
Please read my first post its not about tuning or valve adjustment.
