Heel shifter
Old Feb 22, 2007 | 11:48 PM
jbleim's Avatar
jbleim
Default Heel shifter
Greetings All,
Does anyone know where I could pick up a new heel shifter that extends past the rear of floorboard? My size 12 feet with boots don't work so well with the stock setup. My bike is a 07 Street Glide if that helps.
Thanks much!
Regards,
J.B.
Old Feb 22, 2007 | 11:58 PM
dawg's Avatar
dawg
Default RE: Heel shifter
http://www.kuryakyn.com/products.asp...ey&ci=2416
Old Feb 23, 2007 | 12:04 AM
soos's Avatar
soos
http://bellsouthpwp.net/e/z/ezbrake/index.htm
Old Feb 23, 2007 | 12:05 AM
fatboylust's Avatar
fatboylust
Not sure why these are limited to 1984-2003 unless the spline changed, may be worth check it out. You can call there tech services # 1-800-338-1747 and ask.
http://www.jpcycles.com/productgroup...ley&page=8
Hope this helps,
FBL
Old Feb 23, 2007 | 12:06 AM
Smitty0128's Avatar
Smitty0128
remove it (as i did ) cause my size 13 didnt fit. I am looking at ez-brake and shifters though for next years winter mods
Old Feb 23, 2007 | 12:15 AM
doch4m's Avatar
doch4m
jb,
I use the one from Walter's Workshop. Here is the link. It's easy to find once your there.
http://www.waltersworkshop.com/
About $80. Great product, looks like stock, easy install. Adds 2 1/2 inches.
Here is a photo...
Ride on, ride well.
Doug
"I took the one less traveled by,
And that has made all the difference."
Old Feb 23, 2007 | 01:27 AM
brokenfingers's Avatar
brokenfingers
I used the ones over at softbrake, you can specify the length of extent for the lever... went with a half inch back and a two inch forward... a little long, but my size 12 boot easily fits between the shifters on my '07 ultra... hafta scroll down to get to the touring ones.
http://www.shop.softbrake.com/Harley...hift_lever.asp
Old Feb 23, 2007 | 01:31 AM
boulderbean's Avatar
boulderbean
I have softbrake also. Half inch longer in rear and an inch longer at the front, then set them to be just above the floorboard.
Old Feb 23, 2007 | 01:36 AM
Lil Truckr's Avatar
Lil Truckr
Size 12. Baby size.
I got size 15 gunboats and had the same problem as you so I ditched the heal shifter and now only use the front one. End of problems...
Note the picture shows the shifters prior to my tossing the back one...
[IMG]local://upfiles/21506/F762ECA2CDB34791A47CA55C67A96E11.jpg[/IMG]
Old Feb 23, 2007 | 01:41 AM
Seawolf's Avatar
Seawolf
Guess I'm one of those few who prefer the traditional one shift peg setup.
