23" on Bagger
Old Jun 1, 2013 | 02:18 AM
CPT America's Avatar
CPT America
I've ridden a 23, although haven't made the switch on mine yet and here is what I will tell you to expect:
1. Less sidewall = more feedback from the road (same principle as running those little rubber band low profile tires on a car)
2. Different overall O.D. = slightly different handling characteristics (nothing you can't adapt to, but just understand that its a bigger O.D. than any stock configuration (yes, with the pickard trees you will retain stock rake/trail numbers, but you can't take away the larger O.D.)
3. Rider input is by far the most noticeable difference. Slight movements you may have made before that went virtually unnoticed, will now remind you that you provided the front end with some input. Again, not the end of the world, but you need to remember that the bike is going to be much more sensitive to YOUR input at the bars, weight shift, etc.
If you're going to go with a 23 up front (as am I), I would recommend the pickard trees, and the 1" drop spring kit for the forks to set the frame level again, otherwise the front end of your frame will sit 1" higher than the rear. Pickard includes the fork extensions to accommodate for the 1" lowering setup.
Old Jun 1, 2013 | 04:56 AM
pit1600's Avatar
pit1600
If you can, go direct to a 26"... When you have stock wheel, you want a 21"; when you have a 21", you want a 23"; when you have a 23"...
In fact i'm a little bit jealous, i now want like you a 23", problem is too find a match one at a nice price (and buy new trees and fender too)
dmyster777
Welcome Area Only
19
Feb 6, 2016 01:38 PM
rocwell1229
Welcome Area Only
18
Apr 28, 2014 09:35 AM
jm074282
The General Motorcycle Forum
21
Aug 2, 2013 07:38 AM
junior2
Welcome Area Only
16
May 25, 2010 08:49 PM
NiteRider
Welcome Area Only
23
Apr 3, 2007 08:53 PM
