I am all about increased visibility. So anything you can do to improve your visibility to a cager is good.
That said, motorcycle crash statistics indicate that only 3% of crashes are a result of the motorcycle being struck from the rear. Sure it happens, but not very often. Over 77% of crash impacts occur from the front. So, based on the crash data, it is much more important to increase your visibility on the front of your bike if possible.
How does the sensor differentiate between closed throttle slowing (engine braking) and closed throttle , steady speed going down a hill? I can easily think of several down hill runs that exceed a mile in length. The retarding force would be about the same in both cases.
Wow. I think this is a fantastic idea. Since there's a modular version that you splice in under your seat, it's perfect. I also read you can shut the flashing off to make it act as a regular brake light.
Has anyone kicked in any money yet? I almost paid for one but have never done anything on kickstarter before. Do you lose your money if they don't hit their $50,000 goal?
I want to see some more opinions.
I've backed quite a few items on kickstarter. You are only charged if the project meets its target if not nothing happens.
You can't generate enough braking force with the engine or even the rear wheel to actuate this unit using the described accelerometer. MSF did a nice study on braking and traction limits and G-forces (http://www.msf-usa.org/imsc/proceedi...otorcycles.pdf). The best achieved G-force from rear wheel braking alone is about 0.5G. That's not enough to actuate this unit. So no form of engine braking or rear wheel only braking would trigger it. You've got to use the front brakes as well in order to generate enough force to cause it to turn on and start flashing.
That's why I question this thing's actuation design and find it to be rather rube goldbergish. You've got to be using the brakes, pretty darn hard, before this unit will turn itself on using its accelerometer. Which seems pointless as you've already got an existing brake circuit to tap into. Use the existing light signal that comes with applied brakes. Which is something that is already available on the market. Just have it flash this additional licence plate frame.
I always flash my brake light anyway if the situation warrants it. Just habit I guess but more should do it. For example if I'm first at a light and traffic coming up behind I will grab the front brake lever enough I hear the click of the brake light switch and flash it. You gotta use some common sense here.
