Powervision owner question about engine temp
Looks like he already has power duals with cvo cans and Fullsac baffles.
Or, sometimes I'm working on the upper left of the map.. low rpms/ lot's of throttle positions.
Both are driving heat up. So if you're like me I wouldn't be worrying AutoTune temp. Also be aware that when in AutoTune mode the PV backs 4 degrees of timing out of the tune. But adds it back in when you load the new tune.
So, all of this is to say don't worry the temps while doing AT runs, but notice the temps when riding as you normally would.
I took my stage 1 07 EGC (96ci) with K&N, PV and SE slipons out all day yesterday in high 80s low 90s heat and my average Engine Temp was about 240, while my oil temp on the McEwan oil gauge was reading between 200 and 215'F. But, again, that's NOT in AutoTune mode.
There's a great thread over in the Ignition/Tuner section you should start monitoring. All the PV experts are over there. (I'm not one)
and to unlock your pv it is 199, not 100.
2012 EG Classic with 4" XCR exhaust and SE air breather, and dyno jet map, not Fuel Moto's.
