Oil drain plug o-ring
Old Jun 2, 2013 | 04:23 AM
dansflhti's Avatar
dansflhti
Default Oil drain plug o-ring
I've tried the search button,but man that drive me nuts.Can anyone tell me the specs,dimensions,or part#(not Harley) for the oil drain/primary plug o-ring.
Thanks
Dan
Old Jun 2, 2013 | 05:26 AM
SpiderPig's Avatar
SpiderPig
Here is a link to another thread with the McMaster-Carr listing
https://www.hdforums.com/forum/dyna-...ring-size.html
Old Jun 2, 2013 | 06:00 AM
vegashd's Avatar
vegashd
11105 is hd part number
Old Jun 2, 2013 | 06:02 AM
Iceman24's Avatar
Iceman24
Now it's time to go to your local HW store and stock-up on a few b/c HD charges 4x a pop for that little rubber seal. If you look closely, they probably had an HD logo stamped in it so they can jack the price.
Old Jun 2, 2013 | 06:55 AM
grbrown's Avatar
grbrown
I learned early in my biking career that there are more variations in O ring size and type than is healthy! You can either expend a lot of effort messing around to find a suitable one that fits, or do the sensible thing and get the right part from a dealer or local indy. Life is too short to fuss around trying to save a few cents, indeed you will probably spend more while looking around than the cost of a handful of the genuine article!
Old Jun 2, 2013 | 07:32 AM
journeyman's Avatar
journeyman
If you're going to the hardware store, ask for an o-ring size 013.
While a standard o-ring material would work (Buna-N), I would get Viton instead if it is available due to it's higher heat and chemical resistance.
Old Jun 2, 2013 | 07:33 AM
BikerV's Avatar
BikerV
Exactly!!. From many years of auto repair I kept a big box of "o" rings. None of them seemed to really match the HD one. Even though new neoprene "o" rings and seals last longer than rubber ones did, I don't "Stock up" on seals, rings and gaskets like I used to. I got tired of throwing away old disintegrated dry rotted seals that I kept "in stock". Because I'd find myself taking a ride to the dealer to buy new ones when a job came up anyway.
And to try and find a replacement for them seems ridiculous to me since they are so dirt cheap. What are going to save? 2 cents per ring? Just buy the factory spec part.
Old Jun 2, 2013 | 08:46 AM
bohica48's Avatar
bohica48
+1, the 013 Viton is what I have used for all my oil changes.
Old Jun 2, 2013 | 08:53 AM
kwo51's Avatar
kwo51
I hate the plumbers dope some are using.
Old Jun 2, 2013 | 09:17 AM
Punjabi Rider's Avatar
Punjabi Rider
HD O rings are fairly cheap I order my oil filters and O rings by a dozen from Lakeshore HD or whoever offer 20% off no sales tax.
