Solutions for valvetrain noise!!!
For me, it's ear plugs and volume adjustment on my radio, What Noise????
Not going to play around with pushrod adjustments until this winter since the bike "appears" to be running fine. Don't want to adjust nothing prior to a big trip.
I have postponed my Tail of the Dragon Trip now twice and I'm hoping to go next weekend if the weather cuts me a break.
Question, since the 20/60 didn't help, do think some Lucas Treatment may??
So he talked me out of it and I just did another 5,000 service running Mobil V-Twin in the summer (15W-50 in the winter - it flows way faster in the cold,) which I've run for the last 80,000 miles.
I've got the quieter 95" '00 short stroke motor ( that doesn't run as hot as newer bikes,) relatively mild Andrews 26 cams, and recently shimmed rocker arms.
When it's 80 degrees or so, the motor sounds great, just a slight "sewing machine through a bedroom wall" sound that I can certainly live with.
But yesterday it hit 94* and I rode to Greensboro HD for their summer bash on backroads (nice ride, 75 degrees) then over to Burlington HD for their girl contest (hammer down across I-40 with temps around 90.)
When I pulled into Dealer #2 I thought my damn compensator had come loose again, it was making so much racket! I rode it home carefully, and then went out this morning (70 degrees) for 40 miles and the bike sounds good again. I give up.....
So I suspect that if you go with heavier additives, the additional wear on the motor won't be worth it when that motor is going to make a racket when it gets hot anyway.
Me? I'm just gonna' ride the damn thing.
Your right on the noise, my motor sounds the same now as it did on the 20/50 Mobil 1.
If I was running straight 60W I could possible see a problem down the road but the 20/60 starts off the same and may or not build to a full 60W. I'll dump it anyway in the fall after I readjust my pushrods.
Just got back from Maggie Valley area and something is very wrong. Stopped at Colonial HD in Virginia (1st Class Operation). Their master tech said he never heard a twin cam make that much top end noise. He said possible cam chain tensioners (Zippers Duel Pistons) or pushrod adjustment (SE Tapered Adjustables), VThunder 850's lifers at 3 full turns.
Thing is, when cold the thrashing sound is not there. Get it hot and it's crazy noisy.
The Redline 20/60 oil did nothing for the sound.
Pulling the pushrods tomorrow to examine and will reinstall and adjust. Hoping I don't have to go back into the cam chest but who knows.
Anyone have any other suggestions on what to pull apart and check? With the noise the top end is making, I'm ready to douse the bike with fuel and light a match.....Yeah, it's that bad when hot......
