Spark plug gap smaller than spec
Old Jun 5, 2013 | 02:19 AM
my67pnycar's Avatar
my67pnycar
Thats what its all about T-Dog, bonding with your ride and saving the $$$ for upgrades/fun instead of giving it to the dealer to maintain your bike.
Old Jun 5, 2013 | 03:37 AM
T_Dogg80's Avatar
T_Dogg80
You got that right! Wrenching on the bike is almost as satisfying as riding it. Almost.
Old Jun 5, 2013 | 03:50 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Is it snowing up there, already? Actually your mechanic was pretty smart. It increased the advance by about .010 . Probably not a lot as fast as electricity travels at, but more.? Could pre ignition hammered the gap closer?
Old Jun 5, 2013 | 08:09 AM
btsom's Avatar
btsom
Originally Posted by mikelikesbikes
Interesting as any HD plugs I bought were already gapped right close to .40. I'd say if it is running okay leave it be. Conversely an Indy told me to try .25. DO NOT do that!!!!! Ran like crap. I would be curious to know how the gap works out in the long run.
Could you be a bit more descriptive of the actual symptoms? That is a little vague, though I do understand you weren't happy. Loss of power, rough idle, difficult starts, pinging, loss of fuel economy, ran hotter/colder than normal, changed the sound of the exhaust, hesitation when adding throttle etc.
Old Jun 5, 2013 | 08:22 AM
Blue U's Avatar
Blue U
A lot of older engines were always gaped at 25, the leaner the fuel mixture the bigger the gap, if fuel mixture is set richer it could run good at that gap.
Old Jun 5, 2013 | 09:51 AM
gmc's Avatar
gmc
Trying to post an article I have fr. Hot Bike. I haven't found where they have hotter coils for the new bikes since I think with the ECM they have had to upgrade them. I did change my plug wires to the Thundervolt wires for better spark but have had to keep gap .040 since the ECM doesn't like it much wider.
Attached Thumbnails Spark plug gap smaller than spec-sparkpluggapjpg.jpg   Spark plug gap smaller than spec-sparkplugwires.jpg
Old Jun 5, 2013 | 09:58 AM
lionsm13's Avatar
lionsm13
Originally Posted by T_Dogg80
Bored tonight
since the bike runs perfectly and both plugs looked good, should I re gap them or leave them alone?
Ahhhhh think you answered your own question?
Was it necessary to even ask?
Fix it if it ain't broke then, eh?
Old Jun 6, 2013 | 09:53 AM
mikelikesbikes's Avatar
mikelikesbikes
Long story and I hate to type but this was just after having Andrews 37 cams installed along with some other work. Like said, Indy suggested .25 so I tried it. Most noticeable problem was missing, spitting and sputtering. My Road King is an 01 non EFI so your results may vary. I rode it less than a hundred miles before I put new plugs in gapped at .40 and bike now runs much better. Still an issue with the carb I believe as it will occasionally spit and gas mileage is not what it used to be but can't seem to nail it down yet. Have some oil seepage (very slight) at one of the breather bolts so gonna check into that.
Ozark Joe
EVO
Dec 30, 2015 06:50 PM
Beercan321
Oct 12, 2010 12:33 PM
matinees
Sep 16, 2007 03:35 PM
bigtop1
Aug 2, 2007 12:19 AM
SportyPig
Dec 3, 2006 12:42 PM
