wild ones 575
Old Jun 6, 2013 | 07:13 AM
bundy43's Avatar
bundy43
Default wild ones 575
Has anybody went to 575's on the newer ultras yet ? wild one's is saying you don't have to get longer clutch and brake lines,is this right ? I know on the 05 I did .
Old Jun 6, 2013 | 08:54 AM
iwillfixthem4u's Avatar
iwillfixthem4u
2010 SG needed + 4 inches on clutch cable
love them!
Old Jun 6, 2013 | 09:08 AM
bundy43's Avatar
bundy43
does your bike have abs,and did you have to change brake line
Old Jun 6, 2013 | 10:21 AM
Harsh1828's Avatar
Harsh1828
Did my 12 CVO ultra and did not need anything longer.
Old Jun 6, 2013 | 10:58 AM
bundy43's Avatar
bundy43
so there is enough slack in the clutch cable and brake line
Old Jun 6, 2013 | 11:07 AM
B00001's Avatar
B00001
You will need a new clutch cable unless you route it under the fairing and not out the hole in the fairing. You can route it out the hole but the cable will be compromised going to full lock. Routing under the fairing doesnt look too bad to me at all.
If you want the cable to come out of the hole in the fairing just get the 4 over cable and save yourself a lot of BS. I have done a couple of them now.
Old Jun 6, 2013 | 11:08 AM
morleyz's Avatar
morleyz
I put them on my 2012 Ultra Ltd. last fall. Stock brake lines, but I did a +4 clutch line because I wasn't comfortable with the length. Stock probably would work, but why risk it...clutch cable is an easy swap.
For what it's worth...I LOVE the bars. They're perfect for me. Hardest part is the wiring...took me 3 tries and then I had to solder all of the connectors in the bars because they kept coming undone and giving me TBW errors.
Old Jun 6, 2013 | 11:16 AM
Da Shadow's Avatar
Da Shadow
Yes you need longer clutch cable. Stock would probably work but I did not want to chance activating the clutch when turning tight. All the wiring fits inside including the chrome and rubber heated hand grips if you route the grips wires through the drain hole in the left switch housing. Right side no problem. They are very comfortable.
Old Jun 6, 2013 | 08:22 PM
'05Train's Avatar
'05Train
2010 FLHTK needed a +2 clutch cable and brake line.
Old Jun 6, 2013 | 08:33 PM
jpit11's Avatar
jpit11
Have them on my 2013 SG. Used a clutch cable from a softail crossbones. HD part no 38788-06C. $36.00. Got the advice from another forum member. Here's a pic:
[IMG][/IMG]
