Hdpdplus Install Help!
Old Jun 9, 2013 | 11:15 AM
richb1's Avatar
richb1
Default Hdpdplus Install Help!
I'm in the middle of installing the Iron Cross ipod interface and I'm unclear about inserting the units two wires into the # 19 & 20 bays of the 23 Pin Connector. The two wires on the HDPDPLUS have a "T-pin" at the end of them. Am I COMBINING the existing wires, WITH the HDPDPLUS wires, OR am I REPLACING the existing wires? And, do i cut off the connectors on the two HDPDPLUS to fit them into the 23 Pin Connector. Also, note all the tape around the 23 Pin Connector. Can I cut some of that away to get in there? Sorry to be such a mechanical newb, but man, I'm trying. Thanks for any help
Old Jun 9, 2013 | 12:19 PM
In2It's Avatar
In2It
Not sure if you have the updated kit or not.You can and I had to cut back the wrap on the harness to get at the two wires you t-tap into for power and ground.
Old Jun 9, 2013 | 02:18 PM
richb1's Avatar
richb1
Thanks for the help 2In2It. I finally figured it out.
Satan
Feb 29, 2016 10:40 AM
Ironhead666
Electrical/Lighting/Alarm
Jun 15, 2014 07:22 AM
Mark98012
May 1, 2012 01:56 PM
Doc Danielz
Apr 9, 2011 09:47 PM
jrsmith_80
Apr 1, 2008 11:34 AM
