Race Tuner
Old Feb 24, 2007 | 10:49 PM
stilltired's Avatar
stilltired
4th Gear
Default Race Tuner
need help. Downloaded race tuner... first time it read the ECM and was good. disconnected when done, but tried to start bike, bike would not start... replugged in and went through process again, would not read ECM anymore... said VIN etc Not Found. anybody know what to do?
Old Feb 24, 2007 | 10:52 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: Race Tuner
ORIGINAL: stilltired
Make sure you have selected the correct COM port and also make sure you have turned the switch at the handle bar to "ON" as well as the ignition. Make sure your laptop, if using one, has a constant power source.
Old Feb 24, 2007 | 11:21 PM
stilltired's Avatar
stilltired
4th Gear
thanks for the suggestion, but did all that. Even tried to reset the ignition, but still nothing. at a total loss now.
Curious if some race tuners need to be installed by dealer for the initial installation? then I can fine tune from there?
Old Feb 24, 2007 | 11:44 PM
UltraKla$$ic
Definitely not the case as I flashed mine twice without any problems.
I wonder if you tried flashing with the wrong map and when you attempted to start it the ECM thru a code...........may have to trailer it to the dealer for them to reset your ECM.
EDIT: I was in conversation with someone and I can't remember who or when, but I vaguely remember a "ritual" that could be done if something like this was to happen but I cannot confirm the details...............age catching up with me I guess.
Post this question in the Electrical/ECM/Tuner section........someone will chime in a offer an answer.
Old Feb 25, 2007 | 12:00 AM
stilltired's Avatar
stilltired
4th Gear
First time it read the codes with no problem, everything on the ECM read fine, said download complete, but bike wouldn't start. I kinda figured I tried everything I know. been working on bikes for quite a few years... can pull apart the motor but don't know crap about electronics. was trying to save myself a trip to the dealer just to recalibrate my computer. I guess this is what I get for trying to make my 103 a lot faster. More headaches.
Thanks so much for the help and the info though. Really appreciate it.
Old Feb 25, 2007 | 02:10 AM
cjuetten's Avatar
cjuetten
Does your fuel pump kick in??
I had the same problem, with error message"Corrupt Operating System". Itook itto the dealer. They reloaded the firmware (903 download) and then I reloaded my map and allwas fine. I think my problem wascaused buy static electricty. If you don't hear the fuel pump kick in after the down load be very careful, try reloading BEFORE disconnecting or rebooting PC.
I've read where a week Laptop battery has been know to cause this too.
Old Feb 25, 2007 | 03:24 PM
stilltired's Avatar
stilltired
4th Gear
Yeah, the fuel pump does not kick in. I even tried to reset the ignition, hoping that would make it work, but that didn't help. Had the laptop plugged in, so couldn't be the battery. Just said it would not read ECM files. never said anything about being corrupt. Yeah, I guess I have no choice but go to the dealer now and get my system rebooted. Was trying not to have to take it in. Thanks for the info.
sequel909
51
Dec 22, 2025 12:39 PM
Jay Guild
The Dyno Room
18
May 17, 2017 08:23 AM
Staggie
Sep 9, 2015 09:35 PM
rollnthunder
Sep 28, 2013 11:24 AM
JLOCKHART29
Exhaust System Topics
Jun 18, 2007 05:20 AM
