That photo should not be used as a reference guide for much of anything as only one of the plugs (tranny 5/8) is correctly labelled on there. Everything else seems to be labelled as some sort of comedy thing. The one labelled (mag plug) is actually the engine oil drain plug. No friggin idea what the hell "mag plug" is supposed to mean. That and the transmission drain plug, of all the ones pictured there, are the only ones which should be removed for fluid changes.
I had the same problem. its the exhust bracket the bolts on the bottom of the trany
yep had the same exact leak the other day myself
and some folks here helped me out and sure as sheet
that's what it was 2 bolts at the transmission end
almost hand tight .torqued them baby's laid the
Loctite to them and now history.
