What do you keep rear shocks at for pressure
Single rider not much load?
Anybody use zero?
I checked it when I bought it and there was 40!
I know what owners book says but what do you like.
Roadking
Hap
I weigh 185.... Probably about 10 more for the boots etc plus whatever happens to be in the saddlebags.... I run 14 lbs in the shocks - seems to work fine. Never bottom
You get a lot of front end wonder at low speed if you don't have enough air in the rear shocks. Or at least I do.
I started with the factory recommendations and went from there.
I also found that if you put too much air in the shocks, she gets tight in the turns.
I like her a little loose......the bike that is.
I run 20 1 up, 2 up, with or without TP and never had any issues except maybe a little stiff 1 up and the headlight a little high when 2 up, but not enough worth me worrying about. Combined weight with my skinny ol little over 300#
