Cruise Blowing Fuse
Old Jun 20, 2013 | 08:37 PM
MichiganDave's Avatar
MichiganDave
Default Cruise Blowing Fuse
So last Sunday was out in the middle of nowhere on a fathers day cruise. Riding along the freeway I decided to turn on the cruise which I haven't used since last summer. When I hit the switch the red light came on as did the red light on the instrument gauge. When I went to set the cruise on the switch near the throttle the bike died. Turned out the ignition fuse was the one that blew out. I swapped it with the radio fuse and the bike fired back up. For kicks tonight I put a new fuse in the fuse box and the same thing happened again. Anyone else had this issue or any ideas what may be causing this. Last thing I want to do is end up at the stealer. The bike is a 08 Ultra Classic Electra Glide.
Old Jun 20, 2013 | 08:53 PM
Jinks's Avatar
Jinks
Yep, it's a homotron. A queer electron that goes around blowing fuses............
Old Jun 20, 2013 | 10:18 PM
Chunker's Avatar
Chunker
On the newer models the cruise is also on the circuit for the cigarette lighter. If you have that feature, might check connections or remove what ever is plugged in.
Old Jun 21, 2013 | 08:22 AM
spiritrider48's Avatar
spiritrider48
Check for a bare wire. When I installed mine it did the same thing.
Old Jun 22, 2013 | 03:12 PM
MichiganDave
Didn't install it. Cruise was factory installed. Never had a issue for the last 5 years with it. I have not added or changed anything to the factory set up. I assume the switch at the switch housing is not the problem because the fuse does not blow when I turn the switch on. The fuse goes as soon as I hit the set switch near the throttle. Any more ideas where to start?
RIDERV700
EVO
16
Jul 17, 2020 08:33 PM
OZARKTOAD
Jul 7, 2018 01:38 AM
DMetcalf
General Topics/Tech Tips
Jul 28, 2014 02:36 PM
tatertot
Nov 2, 2008 07:18 AM
Ohio Thunder
May 21, 2006 11:03 AM
