Condor Wheel chock ???????????
Old Jun 22, 2013 | 06:24 PM
SkipCarey's Avatar
SkipCarey
Default Condor Wheel chock ???????????
I have a helluva time gettin my SG out of this thing by myself ,no problem with help but Im mostly solo, any suggestions would be greatly appreciated
Skip
Old Jun 22, 2013 | 06:42 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Well I cannot offer any help but can confirm I have exactly the same problem. I have tried different adjustment settings with front swivel bracket with no luck.
I'm interested to hear if someone has figured this out also.
Old Jun 22, 2013 | 06:46 PM
Badfinger's Avatar
Badfinger
I'm glad I'm not the only one in fact I had to use my jack to get my Ultra out! I must have it setup wrong........
Old Jun 22, 2013 | 07:26 PM
SkipCarey's Avatar
SkipCarey
bumpity
Old Jun 22, 2013 | 07:29 PM
kdodd's Avatar
kdodd
I have one for my 03 FLHTI, I have mine set on the second hole closest to the end facing me, I pull mine out with no problem. You have to play with the different settings to see what works best for you.
Old Jun 22, 2013 | 07:52 PM
lh4x4's Avatar
lh4x4
I am 73 and no Hercules but I have no problem with pulling the Ultra out of them.
The set up is very important. When your bike is in the Condor look at the base the wheel is resting on. It is supposed to be level. If it is dipped down that is hard to pull the bike uphill to get it out.
Move it forward until the platform is level. That is also the way it has the most tension forward to hold into the front. If it is touching the base when the tire is in it then there is no forward leverage to hold the bike up.
If you are having trouble I am sure it is not set in the correct location for the tires diameter.
Old Jun 22, 2013 | 08:56 PM
Brian MD.'s Avatar
Brian MD.
I have no problem getting my Softail Custom out of it. I am in the second hole from the end facing back of trailer. Takes a good tug and comes right out.
Old Jun 22, 2013 | 09:07 PM
thinksnow's Avatar
thinksnow
Not sure which hole mine is setup in but I was having trouble at times.
First, make sure you are in neutral. This seems stupid but it makes a huge difference with my bike.
Second, mine was sliding a little everytime I pulled on it. I put a ratchet strap around the stand and fastened it to the wall. Mounting to the floor would be best but I move the bikes around too much.
After doing these little things it was MUCH better. Just a little tug and off to the races.
Old Jun 22, 2013 | 09:09 PM
Pelonz's Avatar
Pelonz
I had issues till I bolted it to the floor. Now I just grab the bars and compress the front end down giving it a yank back on the rebound .... out she comes
Old Jun 22, 2013 | 09:43 PM
fj1200's Avatar
fj1200
I have mine set to the fifth hole from the open end
