Audio problem
Old Jun 26, 2013 | 12:14 AM
dynacop25's Avatar
dynacop25
Default Audio problem
Posted this in the audio section as well but I figured I would get more responses here.
Just purchased a 13 FLHTK... when I plug my iPhone or iPod nano into the aux jack I only get sound from the left speakers... this is my first bike with a fairing so I am not sure if this is normal or not... anyone else ever experience this?
Old Jun 26, 2013 | 12:21 AM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
Warranty!!! Maybe a solder break on the aux jack mount to the right speaker wire inside the HK head unit itself.
I assume you have sound from both speakers when listening to a cd or the radio?
1st try a different aux iPod cable and if problem exists - back to the dealer for a fix under warranty pal!!
Good luck
Old Jun 26, 2013 | 12:28 AM
dynacop25's Avatar
dynacop25
Good luck
everything else works fine going in for the 1000 mile service on the 6th... I'll have them look at it if the new cable doesn't cure the problem
Old Jun 26, 2013 | 12:36 AM
IM2FA5T4U's Avatar
IM2FA5T4U
Had the same issue with mine. Turned out to be a cheap cable. I picked up a better quality cable from bestbuy and it has worked great since.
Old Jun 26, 2013 | 06:43 AM
pontiac69's Avatar
pontiac69
Clearly not normal to only have one speaker with using the aux jack. I would say try a different cable as well. If not fixed then its the jack on the radio
Old Jun 26, 2013 | 06:49 AM
danzio's Avatar
danzio
Make certain you are plugging the cable in ALL the way. It's easy to feel the plug engage and think it's fully inserted when in fact only one channel is connected.
Old Jun 26, 2013 | 06:52 AM
FXR_Hamster's Avatar
FXR_Hamster
Had a bad cable a while back did same thing. Upgraded to quality plug in cable and solved the one side sound.
Old Jun 26, 2013 | 08:31 AM
fireman9170's Avatar
fireman9170
sounds like warranty issue to me
Old Jun 26, 2013 | 08:44 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Agree, and use a quality cable. Try not to plug/unplug/plug/unplug that cable very much. Repeated too often that action can break the very tiny solder pads that hold the Aux jack to the circuit board. Here is what it looks like inside:
Old Jun 26, 2013 | 09:31 AM
yellowted's Avatar
yellowted
definitely look at the aux cable first. i cant remember exactly how may black lines are on the plug but lacking one would be your problem.
andrew
