What is "fall-away"?
Old Jun 26, 2013 | 08:57 PM
TUCCI's Avatar
TUCCI
Originally Posted by KCFLHRC
Great video....doesnt get any easier than that.
Old Jun 27, 2013 | 03:00 PM
skratch's Avatar
skratch
tucci,
hope you don't go by that method to check the fallaway on your road king. the procedure for checking on the touring bikes is backwards from that due to our triple trees being mounted backwards.
the procedure for the touring manuals i posted up above.
Old Jun 27, 2013 | 03:39 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by skratch
thats all fine and good, but this is not correct for a roadglide. the triple trees on the touring bikes are 'backwards' so you can not do this test on the. on the touring bikes, the test is much easier actually. make sure the front and back are the same height off the ground, then turn your handlebars all the way to the steering stop. then let go, and count the number of swings, or partial swings, until the front end stops. the current spec on a roadglide is 1-2 swings. it is higher on the batwing bikes.
basically, this is just a quick gauge for measuring the amount of preload on the steering head bearing. if the bearing is too tight, you'll get jerky handling. if its too loose, then you'll get the wobble.
I was getting ready to post the correct TOURING bike info, but you beat me to it. Self centering trees don't fall away. That's why touring bikes are so stable at slow speeds.
Old Jun 28, 2013 | 10:53 AM
Mike's Avatar
Mike
Exactly. On a touring bike, it's called the "swing-by" adjustment.
Old Jun 28, 2013 | 11:29 AM
baust55's Avatar
baust55
so is the road king test difrent than the bat wing test?
Old Jun 28, 2013 | 11:35 AM
shooter5074
Nope, same
Ziaon
Jun 19, 2019 11:40 PM
joe momma
22
Jul 30, 2012 01:56 PM
Roadking Cal
May 22, 2009 11:41 PM
trever.thompson
Road Trips
Apr 5, 2009 08:07 PM
20NightTrain03
Northeast
50
Mar 9, 2009 06:52 PM
