Primary Noise
Old Jun 29, 2013 | 09:36 AM
Assegai's Avatar
Assegai
Originally Posted by WildBill2566
Oops, just had a thought. Does the stock rotor need to be changed, and if so is it included in the SE comp kit.
If not apart from gaskets what else isn't included in the SE kit that I will need?
Thanks.
http://www.harley-davidson.com/store...in-compensator
http://www.georges-garage.com/trans_06_up.htm
You will need outer/inner primary gaskets and new bolts that secure the inner primary to the engine. Also some means to lock the (primary drive locking bar?) chain while removing/installing comp bolt/mainshaft nut (left threaded).
Old Jun 29, 2013 | 02:39 PM
WildBill2566's Avatar
WildBill2566
Thanks for the reply, I had already ordered the kit you have listed.
Made a primary locking bar from 1/2 x 2 alloy bar.
Just wanted to make sure I didn't miss anything.
Old Jun 29, 2013 | 04:12 PM
Bill03E's Avatar
Bill03E
I've been looking online and it seems the IPB taking a dump is a far too common occurrence.
Can't even find an upgrade for 09 and up bikes.
Guess ill have to accept that it needs changing every 20000 miles or so.
No , you wouldn't need to replace it that often, if you would ditch that factory AUTO tensioner, put in a Hayden, Baker, or SE, it will make a big difference in bearing wear.
Old Jun 30, 2013 | 06:33 AM
WildBill2566
Ordered the Hayden last night, read some comments on here and decided that the HD auto tensioner had to go.
I just hope it's just the IPB that is toast and there has been no knock on effect to other bearings.
Wouldn't be so miffed if it wasn't nice weather here at the moment, but couldn't wait till winter, that bearing whine was going to get worse real quick.
lopoko9724
Oct 31, 2017 06:17 AM
BigDogHawg
Oct 16, 2016 09:26 AM
xskuzame
Aug 19, 2014 04:45 PM
jerseyjeff62
Aug 13, 2011 11:35 PM
krom nutz
Dec 15, 2010 05:39 AM
