Problem with my new RoadKing, Help?
Old Aug 22, 2005 | 05:11 PM
Quickie's Avatar
Quickie
Default Problem with my new RoadKing, Help?
I have had my new Harley for about 2 months now and I have about 5 thousand miles on it. Ever since new the bike coughs and sometimes stalls while leaving for work in the morning. I let the bike idle to warm up for 2 to 3 minutes and it still coughs. The dealer told me to get the stage 1 installed and it will be better. However its worse and the dealer can not fix it because it is intermittant and will not act up for them. Sometimes it stalls when it is warm, only at slower rpms usually between ist and 2nd gear. Any of you guys have the same problems and if so what was it? Thanxs Quickie
Old Aug 22, 2005 | 05:18 PM
Fandango6's Avatar
Fandango6
Default RE: Problem with my new RoadKing, Help?
Carb or EFI? If it's carb you may need ride a little with half choke. If it's injected it shouldn't do it.
Old Aug 22, 2005 | 05:47 PM
donnathedoc's Avatar
donnathedoc
Hey Quickie,
I have a new 05 Road King Classic....my bike was doing the stuttering crap too, even with warm up, etc.,,Mine is FI. My husband bought a techlusion fuel manager for my King and it hasn't stalled or sputtered once since he installed it. This might be what you're looking for.
Old Aug 22, 2005 | 05:48 PM
Markcuda's Avatar
Markcuda
If it is injected, you could have a bad intake gasket.
Old Aug 23, 2005 | 09:09 AM
Quickie's Avatar
Quickie
Yes my king is fuel injected. What is a techlusion fuel manager and where can I get one and how much? Just to elaborate on what the bike is doing, mostly it stalls or coughs when I leave in the morning. Its really bad if I,m on a trip and i stop for about an hour for lunch, when i go to leave the bike is still warm but has cooled somewhat. This is usally the time it runs the worst. I also have noticed its on days that are really hot and humid. The days that are cooler it seems to run fine. All advice apprieciated because my dealer thinks that I,m crazy. Quickie
Old Aug 23, 2005 | 09:44 AM
Grover's Avatar
Grover
Administrator Emeritus
Could be electrical.
A wire could have the insulation worn through and is shorting out when the engine torques under a load.
Just a thought.
Old Aug 23, 2005 | 10:14 AM
HDF Tech's Avatar
HDF Tech
ORIGINAL: Quickie
This will explain it all
http://www.prietoracing.com/fnanny.html
http://www.techlusion.us/bikepages/harley/roadking/
http://www.shopsprite.net/~easternp/...roducts_id=103
Old Aug 23, 2005 | 10:41 AM
Quickie's Avatar
Quickie
I,m very interested, however would,nt the instillation of this affect my warrentee?
Old Aug 23, 2005 | 07:18 PM
Bill918's Avatar
Bill918
Just curious, what state are you in? Most states have a lemon law. If something is wrong with your bike that significantly effects it's operation or value you should be protected by a lemon law. In NJ, where I live, a dealer is given two opportunites to fix the vehicle. After that you can file for lemon law protection. Once filed, the dealer is given one last opportunity to fix the vehicle, or it must be marked a lemon(on the title) and your money refunded. To avoid this, most dealers will be more than wiling to offer you a different vehicle to avoid you filing a lemon law complaint. I would not spend any of my own money adding devices to my new bike to fix something that should not be broken in the first place.
JMHO....Good luck
Old Aug 23, 2005 | 08:30 PM
Big Ted's Avatar
Big Ted
Most states consider motorcycles to be recreational vehicles and are not covered under lemon laws. Depends on the state.
