Loose handlebars
Old Jul 8, 2013 | 09:14 PM
vtdiesel's Avatar
vtdiesel
Sounds like the smartest thing for me to do is just tear down and replace the bushings and loctite the bolts. The clamp is stock and I think it's a one piece.
Old Jul 8, 2013 | 09:36 PM
SBates08's Avatar
SBates08
The stock bushings are not your problem. There's no way possible for the bushings to allow the bars to move in its clamp. All you need to do is tighten your bolts. If you tighten the rear clamp bolts then by default the front bolts get tighter too.
Old Jul 8, 2013 | 09:54 PM
vtdiesel's Avatar
vtdiesel
Should probably remove all the bolts and loctite them though wouldn't you think?
Old Jul 8, 2013 | 09:59 PM
kojak's Avatar
kojak
Get the poly bushings.
Old Jul 8, 2013 | 10:07 PM
SBates08's Avatar
SBates08
I personally don't think the loctite is a necessity. Not a bad thing either tho. It's really whatever makes you feel the most comfortable. The poly bushings will allow for less back and forth travel in the cushioning of your bars but as stated earlier, for bars 10" and under they really aren't needed.
scottylonebull
Sep 19, 2017 02:54 AM
missedem
Sep 17, 2016 02:28 PM
brent1202
2014-2024 Touring Models
11
Apr 5, 2015 06:18 PM
Bagger71
Feb 15, 2013 09:57 AM
BlueNoser
Sep 26, 2010 05:12 PM
