Drive Pulley Pitting
Old Jul 9, 2013 | 07:54 AM
Boomer1143's Avatar
Boomer1143
Default Drive Pulley Pitting
I have a 2012 FLHTK with a little over 12,000 miles on it. I am in the process of replacing the tires prior to riding to South Dakota. I noticed that both drive pulleys have some pitting in the bottom of the grooves. The belt looks good however. I'm not sure if this is something I should be concerned with. I would appreciate any advise.
Al
Old Jul 9, 2013 | 07:58 AM
Def Mute's Avatar
Def Mute
Sand, grit, road debris...
all contribute to small nicks in the metal. Not to mention casting imperfections. The tops of the 'sprocket teeth' are smooth because the belt friction is continuously polishing that area...
Old Jul 9, 2013 | 03:37 PM
btsom's Avatar
btsom
My understanding is that it is normal and contributes to why the pulleys are usually replaced along with the belt. Otherwise worn pulleys will accelerate initial wear on the new belt. Would need pictures to judge if your wear rate is abnormal.
TDSnowSPR
Apr 18, 2014 11:17 AM
Guitar4Him
Jun 27, 2012 04:01 PM
xwhyz1959
Apr 28, 2012 01:52 PM
hcook
Jun 15, 2010 05:41 AM
sublime_ac
Jan 5, 2010 01:54 AM
