Getting ready to install new cams, SE plate, and SE oil pump. Should I replace the bearings? The bike only has about 7500 miles. Been running with Mobil 1 full synthetic oil. Any advice would be appreciated. Thanks
Not hard to do once your in there..Personally, I always do the torrington cam bearings when doing a cam swap. Only takes a few more minutes for a better bearing
I would suggest you replace the bearings with Torrington/Timken. I believe the SE Cam bearing are Timken's.
Yes the SE's are torringtons.
The cam gasket kit from HD comes with stock inners and the last set of bearings that I got in the kit, one of them was missing a roller.
