Should both front and rear pipes look similar? w/pic
Old Jul 11, 2013 | 11:36 PM
Fathertime500's Avatar
Fathertime500
Default Should both front and rear pipes look similar? w/pic
2012 FLHTK with stage one with power vision. Gets hot, pings at times, and sounds like I have an exhaust leak. Pulled all the chrome off looking for the leak and found both pipes very dis-similar. Thinking one is too lean maybe?
Old Jul 12, 2013 | 06:06 AM
Fathertime500
Anyone?
Old Jul 12, 2013 | 06:16 AM
cass's Avatar
cass
looks like the front section got a bit hot. i'm not a wrencher but i had some bub stubbies that i didn't get the gasket set right and i had one blue up on me. i'm sure someone will be along in a bit and give some real advice.
Old Jul 12, 2013 | 06:17 AM
Iceman24's Avatar
Iceman24
Front pipe's definitely showing a sign of running "differently" than rear...did you pull the plug and take a look too (burning white)? Looks like V&H power duals on your scoot - did you plug the O2 sensors, or are you running them as well? Any tuner, other motor mods???
Old Jul 12, 2013 | 06:23 AM
cass's Avatar
cass
......see, told you someone would be by soon.....i'd try looking for the leak at that front gasket.
98FLHP
EVO
Sep 24, 2017 08:01 PM
GlassBikerNC
Sep 23, 2009 08:17 PM
squirrelu
Feb 3, 2009 02:51 PM
bambamblazer
Jan 27, 2009 05:19 PM
jlandis874
Oct 17, 2008 08:40 PM
