Overtightened Front Axle?
http://www.powersportsplace.com/sear...rd=pit%20posse
When you install the bearings, always check that the spacer is snug between the inner races; it can seem like the bearings are seated when they aren't quite there yet - you do not want to seat them that last bit with the axle nut, even if it would do it - and if it didn't seat them, you might know something was wrong because the brake rotor might not line up just right. I also put a film of never seize on the outer bearing race and in the wheel so there'll be less tendency to gall the wheel going in, and help prevent corrosion. That bearing is tight enough you don't have to worry about it spinning - and if it isn't, you need a new wheel.
What you can run into with over torquing is warping the threads on the axle or nut, or both. If that happens, you'll feel resistance trying to turn it by hand; in severe cases the nut might have to be wrenched all the way off, and that may tear some threads loose, too. If the nut turns freely by hand, I doubt you damaged anything.
Does the handle bars get a vibration in them when going into a curve to the right or left?
The reason I ask these questions is, these were the symptoms I was experiencing with an over tightend front wheel from the dealer.
It took about 3 weeks before I really started to notice anything was wrong, when the wheel bearings finally gave up and I went to remove the front wheel, I had to use an impact to remove the large axle nut!!
2006-2007 the large axle nut on the left should be torqued to 50-55Ft lbs
2008-present large axle nut on the left should be torqued to 60-65ft lbs
And never use an impact to tighten them!
Thanks in advance for suggestions.
