Xotic Customs
Old Apr 12, 2016 | 06:38 AM
2010blueultra's Avatar
2010blueultra
Thumbs up
I have had Xotic Customs Air Ride on my bike for a little over a year.
Once you find your sweet spot they are great.
I added an air tank before they released theirs.
I also installed a dual pressure gauge where the Air Temp gauge was in the fairing.
I have an A/M radio and removed CB, so I wired the CB switch to control up and down. I do caution that if you go this route, get the micro relays from DEI made for alarms. They are small and prewired. I was running straight off the switch before adding the relays and burned up the switch after about 4 months...
Shocks set too soft and you will bottom out... too firm and it rides like a rigid frame....
Find that sweet spot in the middle, different pressures 1 up vs 2 up, and you don't even notice bridge expansion joints!
My wife LOVES the ride ...when I set it right...
Lifetime Warranty, and the only Air Ride kit to list 5" travel. At least they were when I got mine.
Y.M.M.V.
Old Apr 20, 2016 | 10:19 AM
dfwhockey17's Avatar
dfwhockey17
Originally Posted by saintv90
They claim it has a 5" range, 3" down from stock and 2" up.
Out of curiosity, why would you want to ride your bike 2" higher than stock?
Old Apr 20, 2016 | 04:38 PM
2010blueultra
I don't ride aired all the way up a lot, but a little extra clearance when needed... loading into a trailer with a steep breakover angle for instance...working on the bike with it aired up gives a little more clearance to clean and work if needed. I use the heck out of mine.
Old Apr 20, 2016 | 08:59 PM
saintv90's Avatar
saintv90
I can get to the rear tire to scrub the white walls easier!
Old Apr 21, 2016 | 06:50 AM
mpr3369's Avatar
mpr3369
What are your usual pressure settings for 1up and 2up? That'll give me a starting point.
Old Apr 21, 2016 | 08:16 AM
saintv90's Avatar
saintv90
I don't have a gauge so I can't tell you. I can tell you I hold the switch for about 5 seconds for riding solo...7-10 sec for 2up. I do not have a tank so it takes a bit to air up.
Old Jun 12, 2017 | 05:36 AM
Drtumolo's Avatar
Drtumolo
Has anyone used their x-series shocks? They look like monroe's only with a shorter extended length so they wont hit your exhaust. Anyone have experience with them?
Old Jun 12, 2017 | 08:10 PM
Drtumolo's Avatar
Drtumolo
I contacted a vendor about the x-series shocks. I was told they are custom made by Monroe for xotic.
Old Jun 13, 2017 | 08:50 AM
chilidogtampa's Avatar
chilidogtampa
do any of these kits have provisions to use the compressor to air up tires?
Terminator69
Mar 23, 2016 07:41 PM
Fearless (old nickname)
Jan 4, 2015 09:42 PM
kyle31490
Electrical/Lighting/Alarm
Apr 26, 2014 10:33 AM
harleyheaven
Sep 24, 2013 09:08 PM
TCruz
Mar 22, 2006 02:37 PM
