35w or 55w hid help please.
Old Jul 28, 2013 | 02:05 PM
1st 96 ultra's Avatar
1st 96 ultra
Originally Posted by In2It
Curious if the your running a bi xenon bulb high and low beam?
yes I am running the bi bulb , works great , I did wire in a switch in the ground wire to shut the light off because I have read that the low voltage when you start the bike can turn off the ballast or blow it or something like that
Old Jul 28, 2013 | 07:53 PM
In2It's Avatar
In2It
Thats exactly what I wanted to know thanks.Ray
Old Aug 4, 2013 | 06:33 AM
hellbob37's Avatar
hellbob37
This is for a headlight on a 13 street glide. Single bulb hi/lo.
Here's the site and product. This company has great reviews on several forums for different applications.
http://www.ddmtuning.com/Products/DD...rcycle-HID-Kit
The hi is activated by a shield moving on th bulb from what I gather
Old Aug 4, 2013 | 08:19 AM
flhxmc's Avatar
flhxmc
If you are going to do it, I would recommend http://www.theretrofitsource.com they have a specific motorcycle harness. I called awhile back and they will build a kit with the harness. Their kits are the best around in my opinion. Good luck.
Mike
Old Aug 4, 2013 | 08:44 AM
btsom's Avatar
btsom
I gather your user name indicates the machine you have. I have an 08 Road King and would like to do the same thing but I'm already using both factory switches and am having difficulty deciding where to put another switch. If you have an Ultra, I guess you had an empty spot on the switch panel. Most H4 bulbs have a rated service life you can find with a little research. Is there any sort of rated service life on the HIDs? One of my concerns is the extra opportunity for failure, obviously the bulb but also the power supply. How many hours or miles in 3 years?
Old Aug 4, 2013 | 09:32 AM
05 Ultra's Avatar
05 Ultra
A stock halogen bulbs life is rated in the hundreds of hours. A HID bulb is rated in thousands. The bulb does degrade though. Rare it will just go out. More likely the ballast would fail. Thats why I would only deal with a company like http://www.theretrofitsource.com. Matt is a stand up guy and stocks his stuff. DDM stock is in China last I heard.
I did a projector HID for my RAM from him and one of the locknuts cracked. I called Matt and 2 new ones were there the next day. You can get cheaper on ebay. But not that kinda service. Matt also hosts a forum for everything you'll ever want to know about lighting.
Old Aug 11, 2013 | 05:23 PM
davidwneill's Avatar
davidwneill
3rd Gear
Default ddmtuning kit
The ddmtuning kit could be backed up with the halogen bulb it replaces. None of the wiring changes you make do anything to prevent that. So, if either the bulb or the ballast went out, you could still place a standard halogen back in there to get on down the road.
I could not find instructions on their site (none came with the kit) that were specific to a motorcycle. (instructions were for car, two headlights).
You don't need an extra switch with this kit.. the same switch that operates the standard bulb functions to actuate the selenoid that moves the bulb in/out. You do need a power and ground source for the relay (there was a spare, switched set of leads in my flhpi that were not being used for anything, worked fine).
There is along, extra lead off the relay for the other (car) headlight. I just cut if off and taped the ends.
Used the 55-watt option, the light is very, very, very bright. I have since ordered an extra Xenon bulb, so I wouldn't have to use the halogen for backup (spoiled by the light).
Old Aug 11, 2013 | 05:45 PM
1st 96 ultra
well sort of but have a 07 now and bought a acc. switch off ebay to run my lights
Old Aug 12, 2013 | 03:44 AM
LoneWolf01's Avatar
LoneWolf01
Running a DDM Tuning 35w / 8000k. Easy install w/ no issues. Extremely bright. Even on dark back roads I still haven't needed to use the hi beam.....
Old Aug 12, 2013 | 08:28 AM
slammed05fatty's Avatar
slammed05fatty
i run 35 watt 6000k in mine, been running for 25k miles and no isuues leaving me w/o light. i did replace the ballast cpl months ago, the light started getting dimmer for a week or so, simple replce and all good. i love mine and have bee nrunning HID for over 6 years and no issues, only blew 1 bulb in my lifetime of them and it was my fault
