Mine has done the same thing. I posted about it last year and a few people have heard it. I've never heard my bike ping while driving it but you can't miss that loud metallic crack when it happens. Never did hear what the cause was.
Both of my 103 touring bikes have done this. It happens when the bike has been idling for a bit (like at a stop light) and just before you gently take off you crack the throttle 'just a blip'.
CRACK - there's that metallic ping that sounds like you just chipped a front piston.
It's detonation. A hot spot on the piston or cylinder head / valve that ignites the burst of fuel before the spark. The engine tries - just for a split second - to run backwards.
Most folks don't seem to recognise it, just assuming it's normal. I freakin' cringe every time it happens.
EDIT - For the sake of the engineers out here, it also happens when a piston '*****' sideways due to a hotspot igniting the fuel / air load unevenly, causing the piston skirt to contact the bore.
2011 to present have the SE comp installed. This noise was related to the old stock comp not saying it is comp noise, just that less possible on low miles.
some have said it occurs when blipping at hot idle. has anyone had a friend blip while listening with stethoscope.
If that thing went off while you had the stethoscope to it you'd blow your eardrums out. If you whacked the front cylinder fins with one of those small ball peen hammers it would be the same.
Maybe data logging with the powervision would show a knock event but I can't bring myself to cause the noise on purpose. Mine only did it one time this season and I wasn't logging then. My bike is in hibernation now though.
Did you ever figure out what was going on...? Bought my 2012 back in October and have only put about 2000 miles on it because of the weather but I rode today and when I was parking it back in the shop....blipped the throttle to get into neutral and that is when I heard it..First time and is definitely not ping>>>>>
Sounds like the compensator doing what it is suppose to. The cause of the kick back is likely too lean at idle, causing the kickback. Had a 2010 Limited and it did it bad when new. After putting tuner on it it didn't do it anymore.
If you can get your comp to bottom out (which usually makes a huge "bump/clang" and not a ping) in neutral with no load on it, yeah... your comp springs are gone and you'd know it as it would make that noise every time you released the clutch in gear and every time you down shifted. Every time.
My money is on "Pinging" which nearly all stock bikes do it when hot - unless it's been tuned. Needs to have a little gas added to the 1000-1500 or so RPMs at 0% throttle and a wee bit added the 2-5% throttle.
