New noise - fuel pump?
Old Jul 29, 2013 | 10:20 AM
morleyz's Avatar
morleyz
Default New noise - fuel pump?
I have a 2012 Ultra Limited with a few upgrades (see sig)
Was out cruising last night and while sitting at a stop light I noticed for the first time a high-pitched squeal. Each time I came to a stop after that I noticed it as well. It sounds a little bit like the sound of the fuel pump when you first turn on the ignition, but it is constant. Seems to be coming from the top of the engine/fuel tank area. Could this be the fuel pump? Anyone else notice this noise above the sewing machine sounds?
Old Jul 29, 2013 | 10:21 AM
taygull's Avatar
taygull
I had my throttle actuator go out, it sounded like the fuel pump when I started the bike. It caused the bike to go into limp mode which is very dangerous..you basically lose throttle! Not good if you are needing to get out of the way.
Don't mess around, take it to the dealer and have them listen to it....
Old Apr 3, 2014 | 03:55 PM
ronbeejer's Avatar
ronbeejer
the thread is a little old, but...Morleyz, did you ever find out what the noise was? I'm hearing what sounds like the same sound in my 2010 Ultra...
Old Apr 4, 2014 | 12:21 AM
Potato_Potato's Avatar
Potato_Potato
It could be that the convoluted fuel lines inside your fuel tank has a pin hole in them causing the fuel pump to loose pressure.
A good test might be to fill your tank and see if the problem persists because if it is a hole in the fuel line it won’t do it when the hole is underwater (so to speak).
gant
May 24, 2013 07:41 AM
gant
May 9, 2013 09:52 AM
swillerbob
Sep 24, 2012 06:08 AM
sammer4u
Oct 20, 2011 12:15 PM
wireman
Apr 28, 2006 04:47 PM
