Trailering Tie-down question
I've trailered many a motorcycle over my 45 years of riding, everything from dirt bike, motorcross to large touring biks and trikes.
#1. Never, NEVER use handlebars as a tie down point!
#2. I wouldn't use the engine guard as a tie down point.
#3. First, buy a good set of soft ties
#4. Buy a good set of tie downs, ratchet prefered.
#5. Use a good front wheel anchor, I like the wheel chock style, Harbor Feight sells a good knockoff.
#6. Use good anchor points on the trailer, use grade 8 bolts, backing plates etc...
Now that you have the trailer set up...
1. Pull the bike into the wheel chock, leave the side stand down.
2. slide the soft ties over the lower tripple trees, be mindful of the break lines etc. loop one end through the other of the soft ties after sliding it over the lower tripple tree.
3. On the left side place one tie down strap hook into the exposed end of the soft tie and the other end into you tie down point of the trailer, take the slack out of the tie down strap, not tight, just the slack.
4. On the right side repeat the left side...Now gently pull the bike towards the right side and tighten the tie down strap, move to the left side and tighten the strap, back to the right side and tighten a little more...repeat as necessary until the bike is secure. I do compress the forks, not compleatly, but its down there good...
5. Grab the handle bars and see if the bike shakes, it'll move a little but should be good and secure in the wheel chock..
As for the rear, I don't always tie off the rear. Depends on the flooring of the trailer. when I do I use two straps. I wrap one through the rear tire and put both tie down hooks in the same tie down point of the trailer, I use a second one and repeat. I tie them down making an X. One strap pulls to the left and the other pills right...I don't tighten a bunch, just secure the rear.
That's it...when you remove the bike, start by removing the rear straps, bike is not moving at this point.
Next, slowly release most of the tension on the strap on the right side, let the bike come over on the sidestand ( that's why I leave it down) release the strap on the left, and then release all of the right side and then left side....back bike out or off trailer...easy..
Bought a 7x14 Haulmark when we bought the Harleys. I have no garage, so it serves dual purpose. I installed front wheel chocks and tie downs for both SG's.
I tie off to soft straps on the lower front trees and compress about 40%. Originally, I tied the back down from the passenger pegs. After a costly trip over the George Washington Bridge, in which the back end broke free and caused me to repaint a saddlebag, I asked a guy at the dealer.
He recommended tying off the rear wheel at about 90 degrees out from both sides. Pulling from both directions really secures the back end.
I've used this method for the last 2 trips from RI to PA and the bikes didn't move an inch!
Hope this helps.
You guys are serious overkill.
I did not compress one time and the straps unhooked themselves on a bump and my bike fell over on the trailer causing $1,800 worth of damage. I compress again and use the HD straps WITH THE CLIP! If I don;t have HD straps on my then I tape up the eyelet.
Picture one is a screwdrive pointing to the lower triple tree.
Picture two shows a yellow tie down strap going over the tree and out the front. I don't use the strap this way, just a visual..
Picture three shows the yellow strap going through the rear, over the top and out the front of the lower tree..
The last picture shows the soft tie going in the rear, over the tree and out the front...then loops within itself to provide a tie down point for the tie down strap ( the yellow ones)
Hope this helps, if you squat down and look from the rear of the tree, you can see daylight, more than enough room for straps.
