I am actually one of the very few who have put a shorter shield on my SG. No, I don't get the wind deflection that one of those tall geezer shields provides, but I do often feel like I am actually riding a motor sickle.....
I vote SG. But don't rent it thinking you will enjoy the tunes over ~60 mph, the stock stereo system sucks.
But as said before, hard to go wrong either way. Both are great bikes and a lot of fun.
From: South Carolina-First to secede and hopefully the next.
I know it's not on your list, but if it's the weight that bothers you why not try a Heritage Softail? That's what I tried and was amazed. I was almost as comfortable on that as I am the RG, but the wife not so much.
For riding the twisties through the Rockies, I would not want a Heritage. It looks a little like a Road King Classic but doesn't handle nearly as well. To get that low slung look on the Heritage (and many of the softail line), Harley sacrificed lean angle. The difference is staggering. A 2013 Road King has lean angles of 33 degrees right and 31 degrees left. The Heritage is WAY less at 24.4 degrees right and 25.9 degrees left. (Figures from H-D website.) A 9 degree difference to the right and a 5 degree difference to the left makes a huge difference in cornering ability. You get a Heritage Softail Classic for looks, not for handling.
I test rode both before buying my Street Glide a few years back.
We have also been to the Rockies in August. While very comfortable at street level, it can get very cold (and even snow) at elevation!
My vote is for the Street Glide:
fairing will protect your body and hands
radio will keep you informed and entertained
lowered frame will be more comfortable and more manageable
gauges will be reassuring
The ride west, up through Independence Pass and into Aspen is absolutely spectacular. Also, you won't want to miss a ride through Rocky Mountain National Park, north of Denver. Awesome!
One thing that was touched on, but not these two models directly, is cornering clearance. How do you ride? I have a '07 SG and '13 RK in the garage, and I have found a huge difference in cornering clearance. So far, I have not been able to scrape anything on the RK, but drag kickstand, floorboard mounts, etc regularly on the SG. If you like to corner hard, I would suggest the RK. Not sure if the newer SG has more clearance.
Also, I am 6-3 and have no problems with the wind on the SG, even with a short windshield. One point well made is the hand protection given by the SG shield. I took the windshield off the RK, since I really don't care for the look. What a drastic difference between the two!
This is a good point. It turns out the rental co does offer the Heritage but I did not consider it because of this very fact. I own a fatboy, love it... but I do have to be aware of cornering. I figured for some Mountain road twisties I wanted the ability to corner a bit more than on a softail.
