Fork swap question
Old Jul 30, 2013 | 11:56 AM
Hunter 1's Avatar
Hunter 1
Default Fork swap question
I did a search and didn`t find the answer I was looking for. I have an 05 RK that I have put chrome lowers and monotubes in the forks, I`m looking at trading for an 09 Road Glide. Can I swap the forks on the RK with the RG ? It would be much easier to just swap them instead of having to take them apart.
Old Jul 30, 2013 | 12:09 PM
Tanker2's Avatar
Tanker2
They are the same forks 2000 to 2013. And I would say yes it would be easier just to change them.
Old Jul 30, 2013 | 12:12 PM
Hunter 1's Avatar
Hunter 1
Thanks Tanker, I was pretty sure they were the same. It will save a lot of work.
Old Jul 30, 2013 | 04:13 PM
ron1026's Avatar
ron1026
I think I remember seeing differnt part # when I was comparing my 2000 flht and 2013 flhx, I know the front forks on the flhx are much stiffer than my old flht.
Ron
Old Jul 31, 2013 | 04:47 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I thought there were differences that showed up when looking at replacement springs and lowering kits, and refill oil quantities for that matter. Though they may all be the same when it comes to external dimensions (diameter, length). Not sure what will happen to ride quality and ride height with the weight differences.
Old Jul 31, 2013 | 12:25 PM
Tanker2's Avatar
Tanker2
I just meant the forks are the same. But if you look in the manual internally the parts are different. And oil amount is even different. I would imagine it's do to the difference in weight with the fairing. So it might change the ride. Also doesn't a road glide sit lower. Sorry for the confusion.
Old Jul 31, 2013 | 12:39 PM
Scrmnvtwins's Avatar
Scrmnvtwins
'02-'05 have 1 cartridge and 1 damper rod fork and the 09 has dual cartridge forks which is the better system....
hoz88
Feb 29, 2016 03:24 PM
spankustang
13
Jan 14, 2013 05:56 PM
blue dingo
Mar 15, 2011 05:31 PM
desertwolf
Oct 31, 2010 01:25 PM
Robocop1127
Nov 1, 2008 07:34 PM
