Melted Plastic On Pipes and My Experience With Easy Off Oven Cleaner
Old Aug 6, 2013 | 04:52 PM
bigskyhd's Avatar
bigskyhd
Years and years of riding and getting crap on the exhaust taught me that a penny was the best friend I had. No quarter or nickel as they potentially scratch the chrome. The copper in the penny is softer and won't scratch. Just an old "trick" from years gone by.
Old Aug 6, 2013 | 05:04 PM
Mr. G's Avatar
Mr. G
My method is to saturate some 0000 Steel Wool with liquid polishing compound and rub lightly. Does wonders for melted boot sole marks and doesn't mar the chrome. No need to heat anything up.
Old Aug 6, 2013 | 06:51 PM
Ragtop's Avatar
Ragtop
Why do you feel the need to post this again?
You already have the same thread going in the general chat area.
Do you really need the attention that much??
Old Aug 6, 2013 | 08:10 PM
JJHOG's Avatar
JJHOG
Originally Posted by Guntoter
Does the exhaust have to be hot every time you apply the easy off?
I use Walmart's brand of Easy Off. Also comes in a can with a yellow top. The exhaust doesn't need to be really hot. Just warm to mildly warm. I use a sponge and spray the EO on it and then I wipe it on the pipe, trying to get a reasonable amount directly on the plastic. Let is stand for a couple of minutes and then begin to scrape it off. If the pipes cool down start the bike up again, let it run a couple on minutes and then do the EO again. Eventually you will get to the point of just needing to rub the EO on with the sponge and then scrub it a bit. When you're satisfied then rinse thoroughly with warm water, let the pipe cool and then put a good coat of chrome polish on.
Old Aug 6, 2013 | 08:34 PM
PrkChps's Avatar
PrkChps
I use a ball of aluminum foil. The foil is not hard enough to scratch the chrome. Works well for me. Even .000 steel wool can scratch your pipe.
Old Aug 6, 2013 | 11:27 PM
roadglider1's Avatar
roadglider1
I have used a penny to remove melted on boot marks. The theory (third hand) is that the copper in the penny is softer than chrome and won't scratch
it- hey it worked- just one more widget in the quiver.
Old Aug 6, 2013 | 11:56 PM
mcain49's Avatar
mcain49
Originally Posted by hilts
I've heard of guys using razor blades too. I would say for whatever you're going to use try it out on a small area first to see if any damage is likely.
I've used the razor blade method and it works very well. The thinner the blade the better. Coat the burned plastic or shoe sole generously with oil or gel type hand cleaner (I use Goop) and let it set for a few minutes. Lightly skim the burned plastic with the blade edge almost parallel with the pipe to avoid scratching. Keep the burned material moist with oil or hand cleaner and use just enough pressure on the blade to remove the burnt stuff without digging into the pipe and scratching. Clean up with chrome cleaner and good as new.
Old Aug 7, 2013 | 12:03 AM
Guitarman_sg's Avatar
Guitarman_sg
I have used 0000 steel wool dipped in soap and water for years for boot marks etc. The soap and water acts as a lubricant to keep it from scratching. Also works great for spoke wheels.
Old Aug 7, 2013 | 04:34 PM
hilts's Avatar
hilts
I originally posted in the touring section because that's what I ride. Then I thought there may be a lot of people who wouldn't see the post so put it in the general chat section. If I breached forum etiquette, my apologies.
Old Aug 7, 2013 | 09:09 PM
beammeup's Avatar
beammeup
Way that works the best for me is warm pipe and put EO on a red shop rag ( dont use microfiber) and liberally put on the pipe. Let the EO sit on the pipe for a few minutes, put some more EO on the shop rag and it comes off pretty well with no scratches. Must turn the rag as it fills up with the plastic. If the plastic doesn't come off with the rag, put a liberal amount of EO on the mark and rub with marine bronz wool . Worked great in getting a heck of a lot of melted frog togg rain suit off after 600 miles in the rain a couple weeks ago. using things to scrape stuff out always gave me bad results.
