Pulled the trigger on a cam...
Old Aug 9, 2013 | 05:34 PM
Hogster 1's Avatar
Hogster 1
Default Pulled the trigger on a cam...
Well I did it! With much help from Jason with S&S. ( That youtube thing rocks!) And a lot of tuning help from Steve with Vance and Hines fuelpac. I got the woods 408-44 cam in and running great. I know that it is very long in duration but I wanted it to sound as good as it runs. I have listened to a lot of bikes with cams, idle, and some you don't really know if there is a hopped up cam in them or not. NOT so with the 408-44. I spent all my money on the cams and install kit, plus the bearing tool so I didn't have any left for a tuner. Fuelpac was very helpful in getting mine dialed in. Dont let anyone tell you that a fuelpac doesn't support cam's. If you had something more usual (like a 222 or a 204's) They would probably have a map for it.
I might try out a Thundermax later on when I get my cash flow repaired.
Right now I am thrilled!
Old Aug 9, 2013 | 05:38 PM
simpkinst's Avatar
simpkinst
Why did you shoot your cam?
Old Aug 9, 2013 | 05:52 PM
Hogster 1's Avatar
Hogster 1
LOL!! I an a gun nut also...
Old Aug 9, 2013 | 06:00 PM
lionsm13's Avatar
lionsm13
Did the cam do you wrong or what?
Old Aug 9, 2013 | 06:06 PM
Fatboy Brian's Avatar
Fatboy Brian
What kind of gun did you shoot it with? Just kidding, considering a cam swap this winter so I've been researching cams myself.
Old Aug 9, 2013 | 06:14 PM
Hogster 1's Avatar
Hogster 1
My greasy rubber band finger gun
Old Aug 9, 2013 | 08:02 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
You took no pictures of your install!
Glad everything worked out for ya. Ride safe brother.
Old Aug 10, 2013 | 05:21 PM
Hogster 1's Avatar
Hogster 1
You would be wrong about that...I just didn't post any pictures of it...
Can somebody tell me how to do that? GriffinDemon is partially right ...I didn't take many pics as S&S Jason tells the story... but I did take a couple.
Old Aug 10, 2013 | 06:01 PM
Turret_plug's Avatar
Turret_plug
How's about a YouTube video of it running? I want cams, don't really care about the performance so much as I care about that nasty sound!
Old Aug 10, 2013 | 06:16 PM
GriffinDenim13FLHX
You might try www.photobucket.com
There you can upload your pics. Go to library on top tab,then upload from browse your pc.After upload goto your library find picture and click on the sprocket,gear icon whatever..you click that and then goto links and it will give you options to add the pic to whatever. Just click on the line you wanna use and it will auto copy then insert into forum reply. Then preview to verify correct then post,
Hope that helps ya man.
