First ride...troubles???
Old Aug 17, 2013 | 04:50 PM
Mental's Avatar
Mental
Default First ride...troubles???
I went for my first ride on my new '13 Street Glide today after having mini apes installed (4 miles on bike). I did notice that when first taking it for a ride the clutch engagement was very close to the bar, meaning I only had to let it out a little before I would start moving forward.
I rode 25 miles and pulled into a parking lot and was admiring the view, bike in first and clutch pulled in. After a couple seconds a knocking sound started coming from the left side and the bike began to shake. I looked down and the whole thing was shaking, it then stalled on me. I gave it a look over and then restarted it and no knocking, but shifting into gears seems more difficult than it did. I rode it home without anymore abnormal sounds coming from it.
I know the bike is new and the clutch cable will stretch, is that whats going on here. I just need to adjust my clutch.
Old Aug 17, 2013 | 04:55 PM
99%r's Avatar
99%r
I would say you need to adjust your clutch cable.
Old Aug 17, 2013 | 04:58 PM
norris's Avatar
norris
Sounds like the clutch was heating up and grabbing. How much free play is at the clutch lever? It is only supposed to have 1/8" of free play. The cable is used to set the free play at the lever. If you have the proper free play then it needs to be adjusted at the clutch pack.
king249's Avatar
king249
Yeah the clutch needs adjusted but I'm not entirely sure about the knock. Get it checked out that could be a warranty issue. You spend that much on a quality bike you want it to work and sound correct.
Old Aug 17, 2013 | 05:04 PM
Yellotang's Avatar
Yellotang
Almost sounds like the throw-out arm slipped.
Old Aug 17, 2013 | 05:38 PM
Mental's Avatar
Mental
That doesn't sound good. Also found out there isn't a wrench in the new harley all-in-one tool kit that fits the clutch adjustment nuts.
Big_Redneck
May 15, 2022 11:54 PM
fastmerc
Shovelhead
May 5, 2014 02:22 PM
Slammed-N-Senseless
EVO
Aug 13, 2013 10:00 PM
BuckeyeGuy525
Sep 26, 2011 01:57 PM
WARG
Jul 29, 2006 10:46 PM
