Clutch issue, please help!!
You very likely have a clutch Spring Plate failure which is a very common problem at about your mileage. If caught early, the repair is fairly inexpensive, but if you keep riding it, you'll likely destroy the entire clutch basket and that can become a very expensive repair. (~$900 - $1,000 if fixed at the dealer)
What happens next and how much it costs to repair depends on whether you're going to do a DIY clutch repair or have it done by a dealer or indy.
You very likely have a clutch Spring Plate failure which is a very common problem at about your mileage. If caught early, the repair is fairly inexpensive, but if you keep riding it, you'll likely destroy the entire clutch basket and that can become a very expensive repair. (~$900 - $1,000 fixed at the dealer)
Get a pic of what you find when you get it apart.
https://www.hdforums.com/forum/sport...ts-batman.html
easy fix , new clutch kit, about 1 hour and you'll be on the road again,
