Salesman just told me that the gps is from Sirius radio and free for 90 days.
The weather and traffic overlays are from SiriusXM. A SiriusXM radio must be installed and SiriusXM radio and weather / traffic are separate subscriptions.
I did see somewhere that you will be able to use Harley Road Planner, but, I like the OP have a Zumo from Garmin and I use basecamp. If it doesn't have a better program than Road planner then it's a deal breaker for me. I too have asked the question on another thread about "Who makes the Unit" No answer yet.
Software updates have to be downloaded from the Harley site, put on a memory stick and inserted in the Boom! USB connector. Updating wil start automatically.
I've read from the release notes that a modification has been made to the Boom! software to make updating of new maps possible. My dealer told me that the Navigation bit comes from Garmin. There is no information available yet about Garmin map updates.
You can route your trips using any routing application such as Mapsource or Basecamp. Export your route as a .gpx file to a memory stick. You can import the file in your Boom! system by using the USB interface. However, there is one issue that the MoCo has to solve in my opinion. The number of waypoints or routepoints in one trip is limited to 9. Which makes the Nav system practically unusable for touring purposes.
Wrong. The gps is not Garmin. It is Navi and uses Navteq maps. You have to go to Naviextras and dload the Naviextras toolbox and get your map updates thru them. The maps that come with the bike are from 2012 Q2. There is a map update on the Naviextras website for 2012 Q4. Maybe you should look into this and then go educate your dealer.
The software update you speak of is not for the gps, it is for the bike Infotainment system. The bike comes with software version 1.16 and there is a ver 1.17 update. The update process you speak of is correct.
According to HD Technical Support AND Garmin, it is a Garmin provided GPS.
Hmm, ok I'll bite. How did you come up with this information? I see you dont have a '14 bike. Did the dealer tell you this? Did you contact Garmin? I have a '14 bike and everything in the manual and everything we have to do to update all goes thru Navi and Naviextras. It uses Navteq maps. The gps will read Garmin routes that are saved in .gpx format, but thats about the extent of Garmin.
