Is SERT or PC III Overkill?
Old Mar 6, 2007 | 05:23 PM
ULTRA Gramps's Avatar
ULTRA Gramps
Default RE: Is SERT or PC III Overkill?
EASYGLIDE, Thanks for showing that dyno sheet. I have a stage one download in my bike and it seems to run great. I was starting to think it was not possible with just a download. I have a Reinheart 2-1 coming so things might change.
Old Mar 6, 2007 | 05:59 PM
alexcue's Avatar
alexcue
ORIGINAL: DYNA Gramps
Agreed. Gives me quite a bit of pieceof mind. I've got pretty much the same setup and while i haven't dyno'ed it. The seat of the pants experience, and general good running order tells me, leave well enough alone.
I thought i needed the SERT (PCIII, just doesn't float my boat!), after reading all the glorious reviews of it, but the expense. I'm not planning any more changes to my exhaust or A/C, for a bit anyway.
gunrunner, i appreciate your comments. Seems quite a few people, put down the Stage 1 D/L, but you are one of the first to compliment the techs. In my case, while it may be EPA compliant, my results are positive so far.
Old Mar 6, 2007 | 06:31 PM
Easyglide's Avatar
Easyglide
I was not putting down theStage One download Gunrunner--I meant one sizefits all for "my setup". It would not surprise me to see some variation in a stock bike's A/F mixture within some given range. Either way, ifthe bike keeps running like it is now, I won't be messing with it.The feedback the folks on this forum have given me on my Dynoresults, confirmswhat I suspected --paying for a moreprecise tune would not be worth the money.
Old Mar 6, 2007 | 06:48 PM
DCRANER's Avatar
DCRANER
ORIGINAL: Easyglide
I have an07 FLHRS coming in and was thinking of the same set-up as you. Big concern is running lean / hot in so many posts, but your AFR looks to be in the high 13's which is very nice.
Can you tell me if this set-up helped with any heat issues you may have noticed in the stock configuration, and do you sense it is not running lean / hot.
Old Mar 6, 2007 | 07:12 PM
Easyglide's Avatar
Easyglide
DCraner, I have not had a chance to run the bike for a long distance since the Stage One was done. But based on the Dyno run, I am definitely running a tad richer in the RPM range I spend most of my riding time, compared to the stock set up when I bought it.
The bike runs smooth and seems to breathe better with the SE A/C. I plan on checking my oil temp frequently for a while to see if it has made a difference.
Old Mar 6, 2007 | 07:19 PM
gunrunner's Avatar
gunrunner
ORIGINAL: Easyglide
I know, its just a bunch of guys on here are always blasting the simple stage one download as a waste of money and as I found out thats just not true, as your dyno sheet shows also. Ive seen dyno sheets for SERTS and PCIII that the guys wished they got the results you did. Sometimes it doesn't take the most expensive solution to get great results.
Old Mar 6, 2007 | 10:44 PM
DCRANER's Avatar
DCRANER
ORIGINAL: Easyglide
Good point. I bought the Digital Dip Stick, going to check oil temp.; Stock, After breakin, Stage1/Exhaust, etc. Thinking oil temp. is the real test to see if you are running hot or not.
Enjoy that ride, ride safe.
Old Mar 6, 2007 | 10:51 PM
alexcue's Avatar
alexcue
well the only other variables in my example was the oil cooler, and i switched to Syn 3 at the time they did the Stage 1 (see above).
My average temp on HOT days (80's for example), dropped byat least30 degrees using the digital dipstick. As to what the oil cooler is doing aside from the Stage 1 D/L that's hard to quantify.
Old Mar 6, 2007 | 11:23 PM
Road Glider's Avatar
Road Glider
Easyglide,
Do you know if your Stage 1 Download had the 903 Bulletin incorporated in it? The Stage 1calibrationnumber with the 903 is # 34455-07B/DT and the prior one without is #34455-07A/DT.
Old Mar 6, 2007 | 11:40 PM
Easyglide's Avatar
Easyglide
Road Glide, I had the 903 download completed right after the service bulletin came out. I don't think the two are integrated.My understanding isthat they are mutually exclusive downloads.
I do not believe the903 download has an affect on theA/F mixture. The Stage One apparently does, to account for the larger flow SE A/C.
