Installed Ohlins on 2010 Road King
Old Nov 27, 2013 | 04:33 PM
  #31
sel53's Avatar
sel53
Originally Posted by grbrown
The reason you haven't seen springs posted about on here yet, as you put it, is because most of us have bought our Ohlins from an HDF sponsor who ensures he supplies the correct rate when new. The lesson you have learned is to never buy shocks, especially expensive ones, in a box off the shelf! Buy them from a dealer who does that for you and actually provides a thorough and competent service.
You have put yourself to a lot of unnecessary trouble and effort. I installed mine, set their sag, and Mrs B and I have been happily riding on them ever since! Simples.
I expect Mr. (Owner) of (reputable we'll known business) would take exception to your characterization, and I certainly have no complaints about his service. I did NOT buy "off the shelf" as you imply. From what little I have been able to garner about springs delivered by other vendors, as well as the nature of difficulties I have read from others on here, my efforts have not been unique.
The reason in post, guys, is to help contribute as I can from working a very common and sometimes difficult upgrade.
Hopefully some folks appreciate the extra effort!
Old Nov 27, 2013 | 06:17 PM
  #32
1Canuck's Avatar
1Canuck
Originally Posted by dgdamore
Been thinking about these. Can they be adjusted down to (and effective at) Street Glide length?
Originally Posted by sel53
They say the range of length adjustment is +/- 5mm, so they won't work for the 12" shocks. I'm pretty sure though that there are sets sized for 12", so you might have a look at the Ohlins site or call them.
Sel53
you mentioned that SAG was around 25mm or 1/3 stroke. That makes the shock sit at 12" with rider. did you compare this to your stock shocks?
I posted this when I got the JRI 13B for the FLHX that the stock shock is 12" with or without a rider, thus the harsh ride, the JRI is 13" without and 11.8" with rider weight set at 1/3 sag.
Perhaps if that is taken into account then the Ohlins too will work on the FLHX. What is the eye to eye measure with rider added weight?
Old Nov 27, 2013 | 06:37 PM
  #33
1Canuck's Avatar
1Canuck
Originally Posted by qtrracer
The very first thing you do when installing shocks is to determine whether or not the installed spring rate is correct. If you had done the 3 shock length measurements after installing the shocks(or after the break-in) you would have known where you stood as far as the spring rate spring rate goes. When you received the shocks do you get a detailed sheet on how to go about this? If not you need to contact whomever you bought the shock from to get the details on these 3 measurements and how they relate to spring rate. Sure beats changing springs at a whim and guessing at spring rates and sag settings.
please elaborate on this. what is 3 shock length measurement?
Old Nov 27, 2013 | 06:48 PM
  #34
1Canuck's Avatar
1Canuck
Originally Posted by 1Canuck
Once I came across a graph/table of the spring rate choices and how they applied to weight. I did not bookmark and have not been able to find it again. It visually showed what sel53 changes relate to.
your post goes a long way to show how off the shelf shocks no matter brand do not fit everyone.
OK, I give up looking for that graph. I think the Harley rear shock competition is heating up and the graph was removed. I found several links that should have given this information that are deleted, say to call, etc. I think good information is being used by competitors to establish their own market place.
From memory. there are 3 sizes used for touring springs 23N, 25N & 27N. The 23 overlaps 25, the 25 overlaps the 27 at total weight (bike, rider etc). so if you are in the area of overlap with weight you have the option of softer or harder ride feel with two spring choices, if not then there is only one spring choice. sag can be set using preload with any of the three for the same weight, but if you so not need the 27 for the weight then the ride will be harder than with a 25.
Old Nov 27, 2013 | 07:11 PM
  #35
HOT DAMN!'s Avatar
HOT DAMN!
Old Nov 27, 2013 | 10:57 PM
  #36
sel53's Avatar
sel53
Sel53
You are correct, the sag puts me lower than stock. I dont have the numbers with me (at family for turkey!). But i will look up the center-to-center numbers when i get home. If i remember right, the harley shocks give me 25mm rider sag, but 0mm free sag, so they dont sit as low.
There are some subtle changes in feel because of this, but not what i would expect from lowering ... It is not any slower feeling, if anything it is quicker. Maybe there is a different F/R weight distribution?
I think the three measurements 1/4 racer is talking about must be the free length of the shocks (weight off wheels), the free or static sag (weight of bike only on the ground), and rider sag (weight of bike +rider on the ground). Ohlins has a nice writeup on this in their user manual online.
The 3 spring rates you mention are what have read also. I have the 25N/mm right now which is ok but still a bit firm for one up; i think i am on that edge you mention so i am going to give the 23 a try.
I'll post some interesting numbers when i get home.
Old Nov 29, 2013 | 06:15 AM
  #37
grbrown's Avatar
grbrown
sel53, your shock supplier didn't supply suitable springs! You've been put to a lot of unnecessary trouble due to that. 'Nuff said.
1Canuck, the stated length of a shock is eye-to-eye before installation. So a 12" shock may sag a little under the weight of the bike, then a bit more when the rider(s) sit on it. If it has say 3" total travel, then with sag set correct at 1/3rd the ride height will actually be 11". The benefit of Ohlins/JRI and similar shocks, which have fine adjustment of sag, is that ride height can be corrected to compensate for changes of payload - or solo, duo, loaded to the gunnels! Both Ohlins and JRI are available with different eye-to-eye lengths.
hattitude
Sep 3, 2018 04:51 PM
ve9aa
Jun 24, 2018 10:34 AM
teedoff65
Milwaukee Eight (M8)
Sep 30, 2017 10:31 AM
rprokop63
Feb 28, 2017 09:27 PM
kenfm2000
Dec 12, 2010 10:36 PM
