please help, missing coughing backfiring
Old Sep 15, 2013 | 09:10 PM
MAJOR's Avatar
MAJOR
No intake leak. Or do you all mean a fuel hose leak in the tank?
Old Sep 15, 2013 | 09:30 PM
ke5rbd's Avatar
ke5rbd
Check all the easy stuff first, like new plugs, vacuum leaks or vacuum plugs off on throttle body, and if that is ok have the fuel pressure tested. Not sure what it should be but on late models it is 62 to 55 lbs. when varying the throttle engine running. Very possible the fuel regulator or fuel pump or hole in line in tank. Fuel pressure won't cause a code to be set. Neither will a vacuum leak, but not sure on misfiring plug. A wiring issue to a sensor or bad sensor will set code. Good luck.
Old Oct 2, 2013 | 08:15 AM
steven62's Avatar
steven62
Had the very same problem ... found it to be the "0" ring at the fuel filter housing in the tank. Fuel pressure was dropping off .... replaced it and all problems went away.
Old Oct 2, 2013 | 11:20 AM
cncmike's Avatar
cncmike
I've had this happen twice. Both times it was warped or cracked parts on the fuel pump causing low fuel pressure.
Old Oct 2, 2013 | 11:56 AM
Tucker99's Avatar
Tucker99
What year bike?? ****, is something us guys with older bikes should just replace? This'll leave you stranded.
nzhd
27
Apr 25, 2022 02:57 PM
kcollins
Mar 14, 2017 01:38 PM
neocontra
Jul 8, 2012 05:35 PM
Kowalski
Jun 10, 2010 09:26 PM
texasharleydude
May 1, 2006 12:48 PM
