I would at least open it up on sunny days to check on things. I've used hoop houses and fabric garages and the like for many years. They work well, but they are not waterproof from the bottom, and on days after it's rained, the moisture buildup inside them can be tremendous.
Mostly, I don't want you to flip it back come spring time and find a well rusted bike.
I'd put some dryer sheets under that cover to keep the rodents out
I'm going off topic here but I think I'll try putting some of those in front of my radiator on the old JD tractor to see if it works. Get a next in there every year.
I would hit the bike itself with tons of s100 corrosion protectant before you put her up. Or spring for a storage unit for the winter at a self storage place.
If you are able to run an extension cord to this setup for your battery tender you might also add a mechanics light fixture with a 60 watt bulb that is left on. I have heard that the heat from the bulb helps to keep moisture from forming. This is what I have heard, never experienced it myself. I would definitely ensure a flooring setup to prevent moisture to seep up from the ground.
Get a bag of cat litter and poke some holes in it and leave it in there it soaks up the moisture change the bag every 3-4 weeks cheap way to keep the bike dry.
And seriously consider making a platform to hold it up off the ground to help keep water out of it. If a big bag of desiccant didn't come with it, I'd suggest getting one. Moisture in things like that can be substantial.
Excellent Idea ... I use to spray a coating of WD-40 over the whole scooter ( be careful of the rotors and brake pads ) then in the spring a cleaning and it looks good as new ... Never had problems or "after efects" either.
