LED lighted switches
Old Sep 29, 2013 | 09:13 AM
richvz's Avatar
richvz
Default LED lighted switches
I installed the LED lighted switches on my 2014 Limited they are great if you do a lot of night riding. The illumination is just right not to bright to be annoying when riding and bright enough to tell what the switch is.
I would recommend them if you do a lot of night riding.
Old Sep 29, 2013 | 09:18 AM
LeeH's Avatar
LeeH
Harley switches or aftermarket?
More info please. My '14 limited is coming Tuesday!
Old Sep 29, 2013 | 09:46 AM
NDBadlands4-2's Avatar
NDBadlands4-2
More information please. I did not know that lighted switches were an option.
Old Sep 29, 2013 | 10:14 AM
richvz's Avatar
richvz
They are Harley Davidson part number 71500248 for the Limited $249.95
They are new this year.
http://www.harley-davidson.com/store...ntrol-switches
Old Sep 29, 2013 | 10:24 AM
SafetyMan's Avatar
SafetyMan
Here...
http://www.harley-davidson.com/store...09-71500250--1
A cursory look at the catalog would reveal...
Old Sep 29, 2013 | 10:37 AM
richvz's Avatar
richvz
The 250 number is for the CVO Roadking model
Old Sep 29, 2013 | 11:04 AM
mission's Avatar
mission
Default Install
I was wondering about those. Did you do the install and if so was it plug and play?
Old Sep 29, 2013 | 11:16 AM
richvz's Avatar
richvz
I had it done only because it was in the deal. It is a simple job to do 1. Remove the switch housing covers. 2. Unplug the old switches. 3. remove the old switch Assembly it is clipped around the handle bar. 4. Install the new switch assemblies. 5 Plug connectors into the new switch assemblies 6. Replace the switch housings. 7 Test. you will not be able to see if they are working if it is fairly light out. I suggest close the garage door and turn out the light to check.
I hope this helps
Old Sep 29, 2013 | 11:19 AM
Juan L's Avatar
Juan L
Moderator
Those are nice. Backward compatibility?
Old Sep 29, 2013 | 11:22 AM
richvz's Avatar
richvz
2014 models only at this time
