Squeal from front
Old Sep 29, 2013 | 10:33 PM
oscarg's Avatar
oscarg
Default Squeal from front
I get a squeal from front when I use the clutch or accelerate hard and let off. In other words it seems like it happens when the front suspension is having weight shift back on it. It seem to be worse when cold. the longer I ride on a warm day the better it gets. I put different pads on with little if any change. Any ideas?
Old Sep 29, 2013 | 11:24 PM
HDD's Avatar
HDD
Had similar squeak with engine under load and worse at cold. Turned out to be the upper mount connecting motor to frame (front of engine). Sprayed a little wd40 on the joints and it went away. Good luck.
Old Oct 9, 2013 | 07:43 AM
oscarg's Avatar
oscarg
Interesting I will try that
Ultra Pearl
Sep 27, 2017 07:09 PM
customsoftail200
Jul 1, 2014 08:45 AM
c50plus
Mar 15, 2012 02:49 PM
NVest
Aug 19, 2008 07:57 AM
tphillips
Apr 12, 2006 10:33 PM
