Rain riding
Old Oct 5, 2013 | 07:16 AM
ybnorml's Avatar
ybnorml
Originally Posted by '05Train
I use the S/E Tire Warmer....Don't want to void my warranty.
Wished I'd read the bold print and looked at the pictures first .... it's damn trickery I tell'ya, damn trickery
Old Oct 5, 2013 | 07:18 AM
flhxmc's Avatar
flhxmc
Wow, really? Whomever mentioned letting out some air in there tires is not the sharpest pencil in the box. When you have more of a contact patch you have more of a chance of sliding and hydro planing. In the rain the least contact the better, you want to cut though it not plow it and allow water to get under the tires and create a hydroplane.
Old Oct 5, 2013 | 07:20 AM
smitty901's Avatar
smitty901
Do not under inflated your tires. Disregard any fool that tells you to.
Old Oct 5, 2013 | 07:36 AM
SafetyMan's Avatar
SafetyMan
Probably the same sort of special soul who recommends letting air out of the tires when it's cold so they heat up quicker.
You have a much kinder way of saying what I was thinking...
And if your bike never leaves the garage, the chance of riding it in the rain is slim.
Me? Hell I rode my '14 FLHTK home from the dealer in the rain the day I bought it. I've been caught in hailstorms, SNOWstorms... it happens.
Letting air out of your tires is asinine. Period.
Old Oct 5, 2013 | 07:43 AM
Pete6114's Avatar
Pete6114
36 up front, 40 back tire, all year long, rain or shine. No problems
Old Oct 5, 2013 | 09:11 AM
themensh's Avatar
themensh
Originally Posted by Dirtball
I saw this on a different site and wondered why? I have asked the poster to explain but no answer yet. They stated when it starts to rain, they let some air out of their tires. Now I have not been riding too long (2007) but have been driving all sorts of other vehicles for more years than I can remember. Can someone explain why you would let air of tires when it rains? I cannot think of one good reason to ride on under inflated tires.
What do they do when it stops raining? Here in Florida....you could be deflating and refilling your tires all day long.
Old Oct 5, 2013 | 09:19 AM
Dirtball's Avatar
Dirtball
I finally found out the rest of the story. Owner was on a Nija250 on a RACE track. Totally not the same conditions as the roads we ride on. He crashed on the WET race track, duh.... let 10psi out and ran the fastest lap of the day. I still say DUH !!!!! and don't do it.
Old Oct 5, 2013 | 09:22 AM
risuperglidecustomman's Avatar
Originally Posted by Tx_Rider
For those that "don't do rain", you don't know what your missing. Meaning it's obvious that you don't travel very far. I have been on several multi state trips and sometimes rain is unavoidable. When you plan a trip months out you cannot predict the weather. Once plans are made, vacation is approved and your on the way, "rain happens". You have to ride the plan or sit in a hotel or campground and wait it out, blowing the plan.
With that said, I have rode many a day in the rain on those trips and have NEVER adjusted the tire pressure. I have rode the Dragon in the rain with the factory recommended air pressure. There is a reason for the recommended pressure, it has been tested. I don't claim to be smarter than the engineers that designed the tires so I'll stick with the book.
I've had many multi state 500 mi days! I'm just lucky & I watch the weather!
Old Oct 5, 2013 | 12:47 PM
FLUltrarider's Avatar
FLUltrarider
Originally Posted by 2black1s
Less air pressure equals a larger contact patch. Larger contact patch equals increased traction (although hydroplaning becomes more of an issue with a wider the contact patch). I've never done it nor do I plan to, but I'm sure that would be his rationale.
Same thing can be done if you plan to ride aggressively through some turns.
And just because you let a few psi out of the tires does not necessarily mean they are underinflated. Recommended pressures are a compromise to cover various conditions.
Exactly right. In sports car racing we'd pull the front sway pins to soften up the front end and reduce air pressure in the tires about 4 -5 lbs to expand the contact patch and allow the stiff sidewall to roll a little more to keep the tread more in contact with the road. I think it's more important to move the bike out of the "groove" we'd normally ride in in order to avoid deeper/standing water on the road and be very smooth on the brakes and throttle. I've never monkey'd with the air pressure on the bike and here in Florida I've ridden through some real "frog chokers."
Old Oct 5, 2013 | 01:14 PM
K Melancon's Avatar
K Melancon
I have hydro planned in vehicles with wider tires. The tire has grooves in it, these groves are to channel water from under the tire so you do not hydro plain. The bike will hydro plain when the weight of the vehicle is less Than the water can lift before it squirts out. Letting air out your tire mean that the water will be under the tire longer because of the larger contact patch. Let me put it this way, with my Cajun engineering degree. If I want to go mud riding I need tires with a larger contact patch, balloon tires and let air out if I'm just mudding to increase area. This is called floatation. The ATV did not loose or gain weight but with a larger contact area it will remain on the surface at slow speeds. On a motorcycle I want my rubber touching asphalt or concrete not floating on top the water at speed. Also if you think the grooves give you grip then why doeas Nascar and top fuel dragsters run slicks? Because they not running in the rain that's why!
