Octane rating
Old Oct 11, 2013 | 02:43 PM
  #31
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Originally Posted by jus2anoyu
The only good thing about ethanol?
It has a higher octane rating than gasoline.
But didn't someone post a higher octane meant less power, or did I misread something?
Old Oct 11, 2013 | 02:49 PM
  #32
fabrik8r's Avatar
fabrik8r
Originally Posted by Sharkman73
This is true...E-85 has an octane rating of about 105.
There are MANY benefits to using ethanol and/or higher ethanol blends!
There is just so much bad information out there it's unbelievable & most of the people bashing ethanol just don't have a clue what they're talking about.
I'm not even going to get started this time 'cause I could type 5 pages of factual info & it's just not worth it on a Friday afternoon to get into a fuel debate.
If HD would design bikes to be flex fuel & capable of running on higher ethanol blends & even E-85, emissions would be so much cleaner and pipe emissions would have so much less NOx that we wouldn't need all this emissions crap on our bikes, such as catalytic converters, lean AFRs, new water cooled heads, etc. Engines also make more power running on higher ethanol blends, especially E-85.
Cleaner emissions, less emission controls would be needed, engines making more power using a much cheaper fuel. Yeah, those sound like good reasons for people to hate ethanol....good grief.
& to think....all it would take is replacing a few hoses & gaskets & tank liner with alcohol compatible materials such as Teflon & using different programming in the ECM. The automakers do it...so could HD & we would all benefit greatly, regardless of what the haters think they know.
& before someone starts bashing my opinions, you don't have to agree with what I have to say...that's ok, I know the facts.
& yes, I work in the fuel industry & have for almost 17 years...on both sides. I know my **** & I'll leave it at that.
Good day.
Since it is so easy and such a good idea, How's your HD E85 conversion prototype working out?
Old Oct 11, 2013 | 11:21 PM
  #33
Hammz's Avatar
Hammz
Someone did. Sometimes simple generalized statements can be misleading.
Old Oct 12, 2013 | 06:19 AM
  #34
PKS98S's Avatar
PKS98S
Aside from the ongoing discussion related to the octane rating, should there be any concern for the "age" of the fuel in those storage tanks at the gas stations? What is the usage/turn rate of that higher octane/priced fuel - how long has it been since it was delivered to the gas station - is it treated with some type stabilizer in anticipation of longer storage intervals because of less sale?
Old Oct 12, 2013 | 06:36 AM
  #35
Rog48's Avatar
Rog48
That was me......I miss stated my view But the end result is the same. If you use a higher octane fuel than what your engine needs you could have less power.
Old Oct 12, 2013 | 07:05 AM
  #36
VTL nut's Avatar
VTL nut
Well put fabrik8r, well put.......
Old Oct 12, 2013 | 07:40 AM
  #37
a99miata's Avatar
a99miata
HD E85 prototype would be in a Harley mag or 2 no doubt!
Old Oct 12, 2013 | 08:54 AM
  #38
jus2anoyu's Avatar
jus2anoyu
Let's talk about ethanol from a real world standpoint. I assure you, these are not just opinions, but facts. I have been a master tech for over 30 years, and have seen the positive and negative affects of ethanol.
The good.
Ethanol does have a higher octane rating, and burns cleaner than gasoline. Ethanol also has a cooling affect inside the engine. As any alcohol does, ethanol is trying it's best to evaporate anytime it comes in contact with air. As ethanol enters your engine, it's evaporative quality draws heat out of whatever it comes in contact with as it tries to evaporate.
The bad.
Ethanol is alcohol. It strips any lubricant from whatever it touches. Think about pure gas... It is a petroleum product that contains small amounts of lubricant. It lubricates (ever so slightly) the entire fuel system. Ethanol removes these small traces of lubricant. Ethanol being a derivative of corn also is a minor corrosive. It takes almost exactly double the amount of ethanol to do the same amount of work as regular pure gas. So theoretically 1 gallon of e10 will do the same work as .95 gallons of pure gas.
Our fuel systems are not designed for ethanol. When auto manufacturers design a fuel system for ethanol use (such as e85) they use more robust fuel system components.
The bottom line is that ethanol is not our friend. Unfortunately it's probably not going to go away. Fewer gas stations are offering pure gas. It's something we will have to live with, but being aware of its harmful effects at least you know what you are dealing with....
Old Oct 14, 2013 | 08:08 AM
  #39
Sharkman73's Avatar
Sharkman73
If the parts were available, I would do it.
However, it's not my job to design & engineer ethanol compatible fuel system components for HD...that's what they should be doing & it should be this way from the factory to begin with...just like many newer vehicles on the road, flex fuel. Then you could choose to run whatever you want.
Don't like ethanol, then don't run it. If it were capable, I would run E-85.
giacomo56
Nov 9, 2015 12:46 AM
LunaticFringe
Apr 25, 2015 11:01 AM
Buddy WMC
11
Mar 13, 2013 11:57 AM
nola_rider
Jul 31, 2009 02:50 PM
shovhd
Jun 5, 2009 07:00 PM
