Front FLHTC wheel bearings
Old Oct 19, 2013 | 04:20 PM
prezflyr's Avatar
prezflyr
Default Front FLHTC wheel bearings
Just completed a 2000 mile trip but started off badly.
After about 200 miles the 1st day I noticed my front end was not acting right. I stopped for gas and looked at my front wheel. I noticed the front seal on the left front wheel bearing was spinning on the axle. Looked closer and all the bearings were on the bottom of the race and the cage was destroyed. Got on the phone and called several Harley shops. Only shop that had them was Little Rock and they were very nice when I drove up in a U haul. My 2009 Ultra Classic would have bit the dust if I would not have stopped. Seems they are changing lots of them so you better check yours.
Old Oct 19, 2013 | 06:39 PM
Imold's Avatar
Imold
Don't know about yours, but a lot of bearings today have plastic cages. I had to recently replace a front wheel on my 1200 sportster, came with bearings installed, but when I pulled a seal to look inside, they had plastic cages. Pulled them off and put metal caged bearings in. I've also seen a few bearings that didn't have any grease in them. Imagine how long they would have lasted...
Old Oct 19, 2013 | 10:02 PM
scooter1128's Avatar
scooter1128
prez, how many miles on your bike when the bearing failed? glad you found it before anything bad happened!!
Old Oct 19, 2013 | 10:56 PM
prezflyr's Avatar
prezflyr
40000 miles when she crapped out but I do not know how long they have been going bad. When I saw the bearing it was in pieces and not drivable. I also learned that my Geico motorcycle insurance and AAA had no road service included for pickup and towing. I will address that next week since I just assumed both of them covered road service for my bikes as well as auto.
Old Oct 20, 2013 | 01:01 AM
smithbrl's Avatar
smithbrl
For $10 extra a year my Geico motorcycle policy includes towing-1 tow per "breakdown"-unlimited "breakdowns". They asked me if I wanted it when I signed up.
My front bearings failed at around 40k and again around 85k. They must be some crappy bearings.
Glad you found them before something bad happened.
Old Oct 20, 2013 | 08:15 AM
gmurdock's Avatar
gmurdock
On my SG they have replaced them twice once at 15000 then again at 36000
Old Oct 20, 2013 | 08:53 AM
Lowcountry Joe's Avatar
Lowcountry Joe
You said front left...is yours an ABS bike? If so, it's usually been the right side front that for some reason goes out before the left-side ABS bearing. The ABS bearing is only available at the HD dealership. There are no substitutes for that one. Regardless, glad you spotted it when you did. I am assuming that both bearings were changed by the dealership.
The ABS bearings I have ordered and installed were made in Canada by F.A.G.:
Old Oct 20, 2013 | 09:04 AM
FLHTCU Owner's Avatar
FLHTCU Owner
For me, I change mine when the tire gets replaced. Not quite the same as I don't have ABS, and change them myself. I'd do it even if I had ABS. $40 is just worth it to me to do it.
Old Oct 20, 2013 | 09:10 AM
jeffreydsilver's Avatar
jeffreydsilver
Common problem on the early 25MM axles. My 09 Road King front wheel bearings failed without notice at 14,000 miles. Thank goodness I was only doing 15MPH half a block away from home!
Old Oct 20, 2013 | 09:16 AM
Campy Roadie's Avatar
Campy Roadie
What bearings are you using that are 10 dollars each. A set of 4 wheel bearings is right about 100.00 dollar bill.
