Cruise Control Code 242
Old Oct 22, 2013 | 10:53 PM
BladeRun's Avatar
BladeRun
Default Cruise Control Code 242
(This was originally posted in the do-it-yourself forum but hoping for more exposure here)
Hi all,
The cruise control on my 2004 Ultra stopped engaging. I pulled the codes and 242 shows up as the last 3 attempts. I know this code is for high rate of engine change (e.g., hit ice or slipping tire). However when I was attempting to engage the cruise control, I didn't hit ice, sand or slip the tire. I was just going along nicely at about 70 mph.
I checked the fuse and sprayed some wd-40 at the switch. Still won't engage. Any ideas?
Thanks in advance
Old Oct 23, 2013 | 07:42 AM
btsom's Avatar
btsom
Can't help with your problem, but WD40 is NOT an electrical cleaner, it will eventually make almost any switch fail. It leaves behind an unbelievably sticky coating which holds any dirt that gets near it. That coating may do exactly what it was designed to do, disperse water, but it won't help electrical switches.
my2012ultra
Sep 17, 2022 03:35 PM
BladeRun
Oct 21, 2013 08:24 PM
Proudtexan
Jun 14, 2010 07:43 PM
Lucky 13
Apr 22, 2009 09:27 PM
phxlab
Oct 15, 2006 09:35 PM
