new steering head bearings
Old Nov 1, 2013 | 01:12 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Neck Bearings
Can anyone absolutely confirm if HD is using roller Steering Stem/Neck Bearings? The Part Smart shows them as (Temkin like) Taper type and not ball bearings.
Old Nov 1, 2013 | 01:20 PM
fwb35's Avatar
fwb35
I just got this from another site about the 2014 touring bikes
There is no longer a grease fitting on the steering head for the bearings. Instead, you must DISSASSEMBLE the steering head to lubricate the bearings at 25000 mi intervals. Really?
Old Nov 1, 2013 | 06:23 PM
desertwolf's Avatar
desertwolf
To me this is a big mistake on the 2014's. ( can I say that and not be labeled a hater or troll? ). 25000 miles isnt much mileage. Dealers are going to be smiling with this one. How much labor are they going to charge for this?
Old Nov 1, 2013 | 06:25 PM
desertwolf's Avatar
desertwolf
Wonder how long it will be before someone drills and tapes the steering head for a zerk fitting?
Old Nov 1, 2013 | 07:36 PM
Deucedog's Avatar
Deucedog
I had the infamous 'clunk' on my bike. Took it to the dealer (warranty) and they had it back to me in an hour. Three years later the clunk returned. By this time I no longer trusted the dealer so I took it to a local indy. He called me the next day and said that whoever had tightened the front end had torqued it down as far as it would go. He needed a piece of pipe over the breaker bar to get the steering head nut off. When he showed me the old bearings, there most definitely were flat spots on them.
So $39 for bearings and $75 for labor later I was back on the road.
So yes, the bearings can be flat spotted.
Old Nov 1, 2013 | 09:46 PM
hardheaded's Avatar
hardheaded
i've seen neck bearings flat spotted before after many miles, 25000 isn't alot of miles. i really don't think ball bearings are meant to be side loaded.
Old Nov 1, 2013 | 09:49 PM
hardheaded's Avatar
hardheaded
FWIW ... Roller bearings have a much greater contact area than a ball bearing does.
yep, that's what i was thinking too!
Old Nov 1, 2013 | 10:14 PM
SafetyMan's Avatar
SafetyMan
Won't do any good, they're sealed bearings.
Old Nov 1, 2013 | 10:19 PM
btsom's Avatar
btsom
Just asking, if that is the case then how do the dealers service them at 25,000 mile intervals? We seem to be going in circles with this one.
Old Nov 1, 2013 | 10:21 PM
stro1965's Avatar
stro1965
I believe they are supposed to inspect and replace.
