Dyno Chart on my 2011 SG..
Old Nov 2, 2013 | 12:46 PM
chgofirefighter's Avatar
chgofirefighter
Default Dyno Chart on my 2011 SG..
Not happy with these numbers after taking her from a 103 to 110
Max torque 95 and HP 93 WTH, not happy.. Wanted to be in the upper 100 area but I'm not sure if I picked the correct camshaft or the dyno itself was not done correctly
Headwork was done, installed a 110 piston, V&H Pro pipe, SE259 cams, Roland Sand intake and 110 kit... wonder if the CVO is pulling these numbers???
Old Nov 2, 2013 | 12:50 PM
jus2anoyu's Avatar
jus2anoyu
Who did the work?
Old Nov 2, 2013 | 12:52 PM
jus2anoyu's Avatar
jus2anoyu
Who did the heads? What was the final cr?
Old Nov 2, 2013 | 12:56 PM
xhere's Avatar
xhere
Does it run as good as you expected it to?
Old Nov 2, 2013 | 01:47 PM
NoCoLoco's Avatar
NoCoLoco
I woulda went with SE255 cams
Old Nov 2, 2013 | 02:22 PM
09B29's Avatar
09B29
or SE 204 cams
Old Nov 2, 2013 | 02:25 PM
09B29's Avatar
09B29
Yea I think you should be at least 110 FT Lbs.
.I would like to see a Dyno of a Stock 110 CVO
My buddy has a 2013 CVO Road King and that dam thing is as fast as a Stage 4 103
Old Nov 2, 2013 | 06:23 PM
0ldhippie's Avatar
0ldhippie
Sad build or really conservative dyno. 110s and 259s really need bump in compression and proper headwork. My guess is you got neither.
Old Nov 3, 2013 | 07:23 AM
chgofirefighter
What strikes me as odd is that the DYI mechanic kept the bike for less than 2 weeks, the dyno was performed by Chitown Harley. I'm considering visiting HD myself and inquiring about these numbers and comparing them to a stock CVO hopefully the guy didn't just install cams alone and got the bike dyno and got me good... Who knows! But I will find out thats for sure!
Old Nov 3, 2013 | 07:32 AM
jus2anoyu's Avatar
jus2anoyu
I've seen shade tree mechanics ruin a set of heads trying to port and polish based on race technology. With those numbers, I'd be looking for an anchor behind that bike...
