K & N question
Old Nov 3, 2013 | 07:31 AM
mustangsallysdad's Avatar
mustangsallysdad
Default K & N question
I have recently acquired a completely stock 2006 FLHRSI. It will soon need a new air filter and I was thinking I would install the K & N HD 1499 for twin cam 88's. I won't need to change anything else on the bike because of this, will I? It's just a replacement, albeit higher flowing, filter element. Thanks.
Old Nov 3, 2013 | 07:38 AM
jus2anoyu's Avatar
jus2anoyu
I would say probably no additional changes required. The difference in flow will be very marginal. I think the airbox is more restrictive than the filter. Now would be a good time to consider a stage 1 upgrade though...
Old Nov 3, 2013 | 07:40 AM
1flhtk4me's Avatar
1flhtk4me
Did you read this before ordering.....
"K&N's replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED."
Old Nov 3, 2013 | 07:51 AM
mustangsallysdad
Well, first of all, I haven't ordered it yet. Thus my original question. Yes, I've read the K & N spiel but my question was more regarding mapping issues and such. The K & N is a direct replacement "drop in" element so I'm not concerned about fitment. Just wondered if the slight increase in airflow (which is probably a joke) would affect the computer. I just want one for ease of maintenance.
Old Nov 3, 2013 | 09:37 AM
mwegryn's Avatar
mwegryn
There is a chance that it could lean it out too much. A stage I is probably a good idea if you do. With a stock exhaust, the performance gains will be minimal at best since you aren't increasing the overall flow of the engine with the restrictive exhaust (if more air comes in, it needs a way out). I used to use K&N's on my cars, but have gone back to paper. The reason the oiled element filters flow better is that they allow more through. To me that means more dirt flows into the engine when they are clean. They even claim they filter better as they get dirty. I'd personally stick with an OEM filter. They may cost a bit more to replace over the years, but you'd also be saving a lot more money by not having to do any tuning work. That's just me though.
Old Nov 3, 2013 | 09:44 AM
toad6301's Avatar
toad6301
I have a K&N on my Ultra with IED's and no problem, I
put the IED's on to richen it up for cooling the exhaust
down and they helped for that and more. I have been
a fan of K&N's for quite a while.
Old Nov 3, 2013 | 10:06 AM
jus2anoyu's Avatar
jus2anoyu
The op's bike doesn't have that option. Either just do the filter and rock on, or go all out and do a stage 1 with a tuning device.
Old Nov 3, 2013 | 10:45 AM
toothmansteveb's Avatar
toothmansteveb
There should be no problem with installing the K&N except for the fact that you have to clean and re-oil once in a while. I think you will find that the OEM filter will filter the air better.
Old Nov 3, 2013 | 04:05 PM
mustangsallysdad
What are we talking about and why wouldn't it work on my bike? Not being a smartass but I just got back into a bike after a 20 year hiatus and I'm not really up to speed on all the new terminology and gadgets. All I know is it's a 2006 Road King Custom FLHRSI (injected). If there's something out there to make it run cooler I'm all in.
Old Nov 3, 2013 | 04:45 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
That is an accurate statement, they get more air flow by increasing the micron size of the filtration.
Keep them clean and properly oiled and it isn't an issue for most. Have you ever heard of anyone loosing an engine due to one? Neither have I.
I have one in my ZRX, and a Ness Big Sucker on the HD, which is basically a K&N knock off, I run the one on the HD as an open element, and when I just had the cam case open I saw no signs of wear due to contamination.
Now will it lean the bike out... ya just a little, if you are not running some sort of a tuner time to get one, there isn't a HD ( and a few others) out there that does not benefit from a tuner of some sort ( assuming EFI) because the factory settings are to please the EPA, not to make the bike run right
I have seen car engines destroyed from running no air cleaner though....
