There's overkill and then there's overkill. Just like the guys that check their air pressure in the tires for every ride, check the fluid levels for every ride and so on.
There is absolutely no need to do this stuff that often unless you're aware of a problem such as a slow leak in a tire or an engine that uses or leaks a significant amount of oil.
Putting a battery on a tender religously everyday fits in the same category. For what? Batteries don't go dead overnight unless there is an issue.
And for the guys that claim it extends battery life, what are you saving? For every dollar you save in battery costs over the long haul, you've probably spent more than that in electricity costs to run your tender on a daily basis over that timespan.
Do any of these precautions hurt? No. But are they necessary or beneficial? Maybe to a small degree in certain circumstances, but generally no.
My battery tender gets used for a few hours or overnight if my second bike is sitting for more than a couple of weeks as it often does, but on my daily rider - never.
Here's my opinion... There's overkill and then there's overkill. Just like the guys that check their air pressure in the tires for every ride, check the fluid levels for every ride and so on. There is absolutely no need to do this stuff that often unless you're aware of a problem such as a slow leak in a tire or an engine that uses or leaks a significant amount of oil. Putting a battery on a tender religously everyday fits in the same category. For what? Batteries don't go dead overnight unless there is an issue. And for the guys that claim it extends battery life, what are you saving? For every dollar you save in battery costs over the long haul, you've probably spent more than that in electricity costs to run your tender on a daily basis over that timespan. Do any of these precautions hurt? No. But are they necessary or beneficial? Maybe to a small degree in certain circumstances, but generally no. My battery tender gets used for a few hours or overnight if my second bike is sitting for more than a couple of weeks as it often does, but on my daily rider - never.
Its called a tender for a reason. It keeps the battery levels at the same point no matter what the temperature is where you store the bike. Its not a "charger" its a tender. It probably uses as much electricity as an electric toothbrush charger. Why not keep it on? It takes 2 seconds to plug it into the pig-tail
I just use the tender every couple of weeks or so for a couple of hours until it goes green.
I use one tender, and swap it from the 4 wheeler, lawn tractor, snow blowing tractor, the bikes, and my ragtop.
To the OP heat is tougher on battery life than cold. AZ eats up batteries. Best to be safe and keep it on the tender. I live in the east and keep mine on just about all the time I am not riding. My 5 year old battery seems to turn my bike over a little faster than my buds that don't tender. Just saying.
I'm in MT, and mine is plugged in whenever I'm not riding it. I just replaced the battery this summer. I checked the dates, and it's been 8 years since the last new battery. That should answer why I stay plugged in.
Want to thank people for posts like this.
Dude I bought my bike from told me "one problem I have had with this bike is that the stator plug comes off from time to time and the battery dies. I put it on the charger after getting a lift home by AAA and wiggle the plug and all is well."
First thing I bought for the bike was a regulator plug retainer, new battery (after it died in the line to get my inspection the first day I rode it and wouldn't crank the second day I planed to ride it) and a battery tender."
She is hooked up in the garage now and will stay that way anytime she is in the garage.
If I can get 5 years outa a battery in South Texas it will all be worth it!
Same here. I alternate one BT between several rides, but usually make sure it is on the one I will be running the next day, just to "Top it off".
The more often you drive 'em, the less you have to worry about them. On average, I keep the BT on one for a couple of days or so, then move it to another one, etc.
What ever floats yer boat...
